Hubs wont go back in - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-23-2014, 03:48 PM Thread Starter
drtydzel's Avatar
Send a message via Yahoo to drtydzel
I was helping a friend with a 2004 F250 and we can not get a single set of front hubs to go back in. We had to pull the old hubs out by placing the bolts back in with out the cover and yanking them out with some vise grips. We could not put in my factory ford hubs, his old Mile Markers or his new set of Warns. All three sets slide right in and out of my 1999 F250, but completely refused to go into his on either side of his truck. Could both of his hub bearings be bent somehow. Anyone have any ideas?
Early 1999 Silver F250 4x4 Crew Cab Long Bed XLT
Custom S&B Cold Air Intake
4" MBRP T409 SS TBE Straight Pipe
Edge Evolution
Snow Performance Stage 3 MPG-MAX
Currently Just over 185,000
drtydzel is offline
post #2 of 8 Old 02-23-2014, 03:53 PM
ZMANN's Avatar
Quoted: 1771 Post(s)
bump
WTF ?? lol
We Miss you Ronnie
ZMANN is offline
post #3 of 8 Old 02-23-2014, 04:00 PM
Heavy_GD's Avatar
Quoted: 1644 Post(s)
Feedback Score: 3 reviews
I'm not familiar with this year, but arent the 99 and 04s different hubs?
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #4 of 8 Old 02-24-2014, 02:06 PM Thread Starter
drtydzel's Avatar
I thought we had the same axle and spline counts so they should slip in and out at least
Edge Evolution
drtydzel is offline
post #5 of 8 Old 02-24-2014, 02:16 PM
Heavy_GD's Avatar
sorry man, I'm zero help.
GD
...because Patriot.
Heavy_GD is offline
post #6 of 8 Old 02-24-2014, 02:32 PM
huck2080's Avatar
look at the splines on the end of the stub hub ( outer axle ) sometimes when people pull the axle shaft for ball joints the put it back in with a hammer . it mess up the splines take a file and work around it
huck2080 is offline
post #7 of 8 Old 02-24-2014, 03:07 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 452 Post(s)
99-04 is the same style hub. Usually you have to take a pry bar and move the axle around to center it with the hub. Only way they will go together. By moving the axle around I mean at the spindle/u-joint area. It takes a little manipulating. Good Luck
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #8 of 8 Old 02-26-2014, 04:57 AM
Quoted: 3 Post(s)
I agree with the above. Just be patient and don't try to hammer them back in. I've had them slide right in and, sometimes, they take an hour to get back in. Like said above, check the splines and file down any imperfections.
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
