New 6.7 owner here, suspension question - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 17 Old 02-21-2014, 08:25 PM Thread Starter
Shugster2's Avatar
Quoted: 3 Post(s)
I just picked up my brand new 2014 CCSB 6.7 4X4 and I HATE that the front end sags a little lower than the back. Can I just add one of these.........
http://www.ebay.com/itm/Ford-F250-F3...b87b00&vxp=mtr
And do nothing to the back and be able to run 35's on stock wheel? Thanks for the info and glad to be here!
2014 F-250 FX4 CCSB 4X4 6.7 Tuxedo Black
2" leveling kit (front only)
35x12.5x20 Toyo AT II's on stock wheels (had the nitto trail grappler MT's and only got 28K miles)
LED's on all interior bulbs
Rough Country LED fog's in place of stock
Ranch Hand bullnose with a 23 LED lightbar
Many more coming......
9-11-01........never forget!
Shugster2 is offline
post #2 of 17 Old 02-22-2014, 12:49 PM
Motomez's Avatar
Talk to the guys at Carli they will Level with you
2002 PHP Hydra Chip, Banks Monster Exhaust John Wood Transmission 6.0 Cooler 06 front Axel Pure Performance 6 inch lift and 4 link 08 Rear springs Fox Racing 2.0 Piggy Back Shocks Raceline Renegade 8 wheels with 35 Toyo RT's Auto Meter Gages PSC Hydro Steering Dorman Bellowed up pipes Ford AIS 08 Tow Mirrors
Motomez is offline
post #3 of 17 Old 02-23-2014, 07:50 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 555 Post(s)
Garage
You want to get thicker rubber spring mounts where the coils hit the frame. Forget who makes them but they are available in different heights. That is how you want to do a inch or so increase. Real easy just make sure you don't max out the shocks. If they are topped out they will let you know. Lol
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 17 Old 02-23-2014, 03:54 PM
DTL
DTL's Avatar
Yes, you can use those. 2.5" is a little much, IMO for a spacer like that, but they'll work. For anything over 1.5", I'd personally look at either a replacement spring, or an over-the-top spacer like the folks above are talking about. If you decide to use a lower spacer like the Ebay one you linked to, I'd spend a few more bucks and get the ones from Precision Metal Fabrication. It's definitely a superior product.
DTL is offline
post #5 of 17 Old 02-24-2014, 11:20 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Ford F250 F350 Super Duty 2 5" 4WD Front Leveling Lift Kit 2005 2014 Made in USA | eBay
The only proper way to do a leveling kit is to address the coils, shocks, brake lines, track bar and caster angles. We have kits that address all of the aforementioned to ensure your $60,000 truck doesn't suffer in handling, geometry or ride quality after the installation of a cheaper leveling kit. If you'd like more info, go ahead and post up in here or pm me. Good luck with your build!
OCVeloMan is offline
post #6 of 17 Old 02-24-2014, 01:42 PM
Skyd Ram's Avatar
Quoted: 150 Post(s)
You didn't mention whether your truck was a an F250 or F350.
Generally anything over 1" of lift up front will require longer shocks and a new track bar at the bare minimum to do it "right:.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #7 of 17 Old 02-24-2014, 04:49 PM Thread Starter
Shugster2's Avatar
Quoted: 3 Post(s)
Sorry, it's a 250 and I'll send the PM's. Thanks for the info everyone!
post #8 of 17 Old 02-24-2014, 05:42 PM
mhatlen's Avatar
Quoted: 555 Post(s)
Garage
Come on 1" that's bull---- that truck won't even know anything happened!!!!
You can most certainly go up one inch but watch the shocks because you want a few additional inches for rebounding.
I am in no way buying you need to get your checkbook out to buy his parts for a 1" lift.
7" Icon/Carli Lift
Atlas40
4" SS exhaust
58K Miles on it
mhatlen is offline
post #9 of 17 Old 02-25-2014, 07:39 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
It's not a cognitive thought process of your truck understanding the modification or not, it's a pairing or proper shocks and springs based on travel specifications. George is right and, as a retailer, it's his job to make a recommendation that he can stand behind should the customer have an issue. The front end of the trucks are starved for travel in the factory configuration; anyone with one knows that. Adding even a one inch spacer will have an effect on driveability (ie: now topping out over speed bumps) given the lack of travel and already light caster specs in these rigs.
He's not saying to go overboard, but shocks should be addressed with any lift height given the severely limited travel of these front ends.
post #10 of 17 Old 02-25-2014, 10:35 AM
DTL
DTL's Avatar
1" needing all that ABSOLUTELY IS total BS!! Sometimes I wonder if any of the "parts pimps" have ever even been under one of these trucks?? Having actually measured and tested the range of motion on my personal truck (2014 F250) I can say with complete certainty, backed up my measurements and analytic data, that anything up to and including a 2" lift (either spring or spacer) is well within the travel tolerances of the factory shocks, brake lines, hub lines and track bar.
The idea that some poor guy needs to spend $1500 to level his truck is ridiculous! I see people (here and other places) with a ton of money spent on springs and shocks that are completely unnecessary at the heights being discussed here.
Maybe one of the parts-pimp/suspension-gurus can explain to all of us the geometry difference between a 2.5" spacer lift and a 2.5" spring lift in a radius arm suspension?? What exactly is the difference?? Then maybe one of you can explain how it is that when one of these "$60k trucks that's going to get screwed up" shows up from the factory with the front end offset 5/8" on the stock, non-adjustable track bar, that somehow the earth is going to stop rotating when someone lifts a truck 2.5" and the front end is now only out 3/8"??? (measurements from my truck). Finally, maybe one of you can explain how when the factory shocks have an additional 1/8" of travel AFTER the coil spring is completely unloaded, with a 2" spacer, that somehow a longer shock is necessary?? Are we racing the Baja 1000 now? Planning on jumping your truck much?
I'm sorry to come off a little harsh, but the "shut up and take my money" mentality that seems to be everywhere nowadays, perpetuated by the people that profit from it really pisses me off. People: take your own damn measurements and see what you can and can't do! There's no magic to a solid front axle/coil sprung suspension. I beat the CRAP out of my truck on unimproved farm roads every day (out of necessity) and a 2" spacer lift works flawlessly. I am in the process of upgrading shocks (due to the "rancho" pieces being toasted after only 8k miles) and I *might* put an adjustable track bar on the truck, just because I have a roadracing background and get a little anal about stuff like that. However, for the VAST majority of people, that aren't in a similar line of work and whose most daunting obstacle is likely the speed bumps at the mall, or the dirt parking lot at the dirtbike riding spot, much of the lauded and pimped suspension components, with all their shiny powdercoating and fancy names (not to mention pricetags) are simply unnecessary.
jayz likes this.
DTL is offline
