Lift pictures - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By jetjock15
post #1 of 10 Old 02-21-2014, 07:26 PM Thread Starter
josh.williams506's Avatar
Lift pictures
I've searched but haven't found much. I'm looking for pictures of leveling kits up to 6 in lifts and everything in between particularly on 00-04 extended cab short bed trucks. I'm trying to get an idea of what they look like and how high is too high for a dd/farm rig.
01 f250 ecsb.
6637 intake, wicked wheel, mbrp 4 in turbo back exhaust
Southbend clutch, 6 pos with swamps tunes
josh.williams506 is offline
post #2 of 10 Old 02-23-2014, 10:19 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Type the lift size you want to see in google images and you get lots
huck2080 likes this.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 10 Old 02-25-2014, 08:07 PM
heisman01's Avatar
Quoted: 52 Post(s)
mines leveled (see sig)
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #4 of 10 Old 02-25-2014, 08:33 PM Thread Starter
Thanks Heisman, I used google but it's not the be all end all. Sure I can type in f250 4 in lift, but there are a limited amount of pictures of my body style, and even more so of ecsb...at least using my phone to search that was the case.
01 f250 ecsb.
post #5 of 10 Old 02-26-2014, 04:53 AM
SS4Matt's Avatar
2.5" shackle and hanger up front. And I replaced the rear block with a 4" one
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
post #6 of 10 Old 02-26-2014, 07:49 AM
Mine has somewhere between 5-6" of lift on 35's. I think it is the perfect combination. Enough clearance to have fun offroad, but still able to pull anything I put behind it (as long as goosenecks have an adjustable coupler). I do have the urge to go about 2" more lift so the tires don't rub offroad, but not sure I will still be able to pull a gooseneck.
2002 F350 CC 4x4
7.3L, 6spd, BHAF, 4" MBRP exhaust
TS 6 pos
5" lift, 35's
1991 Chevy Suburban
LT1
8" lift, 38.5" SX's
BIGGER is offline
post #7 of 10 Old 02-26-2014, 04:23 PM
6 inch Fabtech with 37x12.5x20
Name:	2014 F350 006.jpg
Judithgap is offline
post #8 of 10 Old 02-26-2014, 04:58 PM Thread Starter
Thanks guys, keep em coming! In regards to the shackle/hanger kits, since I'm leaning towards. Icon or PMF, does that affect anything? I've read on some 4wd sites that shackle lifts decrease approach/departure angles, affect castor, and cause premature spring wear. Are these statements valid and something to be concerned with? I must just be paranoid or something, because I research far to much on things I intend to add or purchase.
01 f250 ecsb.
post #9 of 10 Old 02-26-2014, 07:15 PM
huck2080's Avatar
i would say no seeing as icon makes a 4.5 and pmf makes somewhere around a 7 habger and shackle
huck2080 is offline
post #10 of 10 Old 02-26-2014, 07:23 PM Thread Starter
That was what I was thinking, just wanted to make sure.
01 f250 ecsb.
