Does anyone manufacture HD rear lift springs? Rear block delete... - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By ZMANN
post #1 of 8 Old 02-16-2014, 10:48 AM Thread Starter
I have the Bilstein BDS leveling kit up front and F350 blocks in the back. My OEM leafs are warped from some heavy loads over the years. I found some new replacement leafs for about $400 shipped. I was curious if anyone knows of a manufacturer that make lift springs that are capable of handling fairly heavy towing if needed. Fully loaded, maybe 12K on limited occasions. I see some folks use the ProComp 22415 springs that are 4-5" lift springs but they only have 5 leafs.
Is there anything out there thats a bit more stout? I would like to eliminate the 4" block completely if possible.
Thanks.
sw99 is offline
post #2 of 8 Old 02-16-2014, 03:59 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 141 Post(s)
Feedback Score: 3 reviews
Deaver should be able to take care of you.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 8 Old 02-16-2014, 04:11 PM Thread Starter
Thanks, I really was just looking to see there was anything mass produced that would fit the bill. The stock set up is fine for what I use it for, I was just thinking I would look into it since I need to replace the springs.
sw99 is offline
post #4 of 8 Old 02-17-2014, 05:04 AM
N.S.D.Q.
Quoted: 141 Post(s)
For the cost they may be out of reach but they are made for what you want to do. I'd give them a call. Be ready for the sticker shock.
post #5 of 8 Old 02-17-2014, 05:32 AM
ZMANN's Avatar
Quoted: 1789 Post(s)
if your wrecking springs due to towing you may want to consider traction bars or some type of axle wrap control
Deavers are nice but they just use more thin leafs I am sure you could mess them up just like the factory springs
i use lift springs, traction bars , air bags and a sway bar on mine for towing
We Miss you Ronnie
ZMANN is offline
post #6 of 8 Old 02-17-2014, 06:57 AM Thread Starter
Sorry, forgot to mention that the springs are warped from the previous owner. The most I will tow is maybe 10-12k a handful of times a year. Other than that, I'll be towing the UTV and utility trailer the rest of the time with regular truck duties.
For the 2006 model year, Ford's OEM base F250 springs was a 4 leaf pack and there was an optional HD 6 leaf option (Same as the F350). I have the upgraded HD 6 leaf springs.
I see the ProComp 22415 is a 5" lift spring that has 5 leafs and says they are rated at 375 lbs./in??? The OEM type replacement springs are showing a 4,400 spring capacity.
I wonder if the procomps could handle the task? I might be able to add a single OEM style overload on top of them for the heavy loads.
sw99 is offline
post #7 of 8 Old 02-17-2014, 07:26 AM
ZMANN's Avatar
06 250 spring was 4 plus 1 bottom flat spring that is supposed to fight spring wrap
and give the spring a overload basically as the arch goes out of the spring under weight it lays down onto the thick flat spring
here is one
HeavyAssault likes this.
We Miss you Ronnie
ZMANN is offline
post #8 of 8 Old 02-17-2014, 10:27 PM
On those Pro Comp springs, make sure it specifies what (if any) blocks are to be used. I have their 22061 6" springs and found out that they're only a 4 inch spring. They are used in the 6 inch lift, but require your factory block. Otherwise, they are matched up with 4" front springs.
Also, I'd recommend air bags like on the picture.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
