2002 F350 front leaf springs - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-15-2014, 01:49 PM Thread Starter
Guys I am truly sorry for adding a thread on a topic I know has been beat to death. I am so confused on what I should do I have given up Google searching for my answer.
My truck has 259,000 miles. It's an '02 350 Crew 4x4 SRW. When I got the truck the front was nose dived.
I put on drop shackles to lift the front about 2 inches. BUT, I think the springs might be worn enough that it is not really level just closer.
I have "V" code springs rated at 2,230 lb each
If I need to replace my springs (Unsure) then I want to go heavier like "X" code 2,630 lb. Everywhere I read, X codes are rated at 6,000 lbs but from what I gather this must be OEM Ford springs only. The 43-818 like from SD Springs is 5,260 lb
I don't want to get new "X" code 2,630 lb springs if I will not gain the extra 1.5 inches or so I am looking for. I am not opposed to putting in the X codes AND the drop shackles. There is also a 43-818HD which is rated at 3940 lb per side.
Advice please.........
Go with generic X codes and the drop shackles?
Go with 43-818HD and NO drop shackles
or add extra leafs to what I have now..
I cant afford a $400 leveling kit or Real X code oem springs.
I know I will possibly need other mods like track bar, etc. Right now I just want to get the height. OH and I plow and it's not a daily driver, I don't care if the ride is stiff.
Thanks sorry so long.
cdorsey50stang is offline
post #2 of 10 Old 02-15-2014, 01:52 PM Thread Starter
One more thing....
How do I know if the stock springs are whooped? They all have negative arches so its hard to tell. I cannot say it rides bad or bounces and my plow only drops the front about an inch when lifted.
Also some guys say X codes do not raise front at all just have more lifting ability. I don't see how this is possible, same weight on front with more capacity almost has to raise it some........
post #3 of 10 Old 02-16-2014, 08:12 AM Thread Starter
Figured out my own solution. Literally hours of Google searches and ordered Pro Comp lift springs. 22210 2 inch lift. I figure since my springs are pretty worn I will likely have a huge gain in lift, new springs, plus 2 inch over stock height. I may be able to put my stock spring hangers back on.
Now the only problem I am having is finding the correct length U-Bolts. I've tried all the popular on-line stores. Anyone have experience? I think I need 9/16" X 3 X 11 or so long. Semi Round. The closest "spring shop" to me is very very expensive because they have no competition.
post #4 of 10 Old 11-22-2014, 04:45 PM
MajorDave's Avatar
So - how'd it go? Any pics? I am in same boat and just bought add-a-leaf, but did not do it yet.
MajorDave is offline
post #5 of 10 Old 11-22-2014, 04:46 PM
MajorDave's Avatar
I looked at Pro Comp - called - and they could NOT tell me what they were rated at - had not clue if they were like the V or X-Code.
post #6 of 10 Old 11-22-2014, 06:10 PM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
Do x codes. Either from the junk yard or from sdtrucksprings. The 5280 lbs springs are the x codes. Return the add a leaf. It will ride like crap.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #7 of 10 Old 11-22-2014, 06:21 PM
MajorDave's Avatar
Ya - damn - I was scared of that...I do need about 2 inches of lift though...suggestions?
post #8 of 10 Old 11-22-2014, 06:22 PM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
X codes will give you anywhere from 1.5"-3.5" of lift due to spring condition.
01 f-250, Standard
The Following User Says Thank You to sbluke55 For This Useful Post:
MajorDave (11-22-2014)
post #9 of 10 Old 11-22-2014, 06:27 PM
MajorDave's Avatar
Thanks man --- gotta start looking for a place to buy em now...shipping will not be fun on those.
post #10 of 10 Old 11-22-2014, 07:52 PM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
So sdtrucksprings.com has them and I looked them up. $238 for both front springs and new u bolts (u bolts are a one time use only). Plus $75 for shipping to my house. So $320ish to your door.
01 f-250, Standard
