Thoughts on PMF lifts? - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By ZMANN
  • 2 Post By Gapowerstroke
post #1 of 9 Old 02-14-2014, 06:35 PM Thread Starter
What are your thoughts on the "entry level" lift kits for the 2011+ trucks? I am thinking about a 2"-3" lift/level kit and although Carli and Icon are held in very high standards here but I am not/cannot spend that much on a lift. So, I see they have what looks like a 3" front, 2" rear lift for my truck for 1K. Comes with shocks, adjustable track bar, control arm brackets, Bilstein 5100 shocks, rear lift blocks and u-bolts, etc. Looks like a solid kit and well thought out. It has front spacers instead of springs but it isn't as expensive as the others and appears to have everything you need except maybe caster cams.
I use my truck to commute around town and tow my 40' toy-hauler to the mx track and such so I can't go very high at all. No huge suspension articulation or off roading. I just put some 35/12.50/20 Toyo AT2's on stock rims and they do not rub but would like a little more space in the wheel wells and maybe some different wheels down the road.
What do you all think???
Steve
Steve M.
2013 F-250 CCSB 4X4 Platinum
Steve M is offline
post #2 of 9 Old 02-15-2014, 12:57 AM
schlutzer's Avatar
Quoted: 18 Post(s)
You can't go wrong with PMF. Good fast service and I've never seen a bad word about them.
I run their rear shackle flip, and it was perfect
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 9 Old 02-15-2014, 03:16 AM
montana6.0's Avatar
Yes great customer service and some awesome products. I got a 2.5" lift from him for my 2010. Everything fit great and is working wonderfully. Only thing I would suggest is swap the 3" spacer and get the icon springs.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #4 of 9 Old 02-15-2014, 03:29 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Cannot go wrong with PMF. Quality and customer service is second to none. Trevor has done quite well for himself
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 9 Old 02-15-2014, 07:31 AM
Steve
Drop down radius arm brackets correct the caster there fore not needing the cams. Pmf is great! Just remember since it has a spacer up front it's gonna ride like stock...but better cause of the bilsteins! Don't think you'd regret the purchase.
jayz is offline
The Following User Says Thank You to jayz For This Useful Post:
Sambowman84 (04-12-2016)
post #6 of 9 Old 02-15-2014, 07:45 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
while PMF is great a 2-3" is such a simple lift I wouldn't have an issue going with even a
a company like Fabtech or just source my own parts like coil spacer /shocks/rear 1 piece block ETC
I would also have a set of airbags for that toy hauler
huck2080 likes this.
We Miss you Ronnie
ZMANN is offline
post #7 of 9 Old 02-15-2014, 08:13 AM
I've got a pmf dual steering stabilizer waiting to go on with my lift. Seems nice and beefy.
2012 CCLB F250 Lariat 4x4 6.7L
Rigid Industries 20" E-Series-Husky Liners-S&B Intake
Pure Performance 4" Triple Threat-PMF Dual Steering Stabilizer-Method NV-315 70R18 Toyo M/Ts
5-0stank is offline
post #8 of 9 Old 02-16-2014, 05:18 AM Thread Starter
Thanks guys for the replies. The kit look quality so when I am ready this is what I will go with. As far as the airbags ZMANN, I thought about those but decided to go with the TORQLIFT load levers instead. Very glad I did, they were easy to install and work great. I don't have to air up or disengage them when I am not towing. I took one of the 3 tabs out and that's it. If anyone is looking for an airbag alternative, those are it.
Steve M.
Steve M is offline
post #9 of 9 Old 02-18-2014, 11:37 AM
Gapowerstroke's Avatar
I got the carli level kit with the front shocks for $895 shipped. That's with the springs. Added a 1" block to the rear for a level ride. I know you asked about pmf and I think their stuff is great but you said you couldn't afford carli when its priced about the same.
huck2080 and Kerry.Staniford like this.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
