lean with rough country lift?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-12-2014, 10:14 PM Thread Starter
stroker007's Avatar
I have a 8inch rough country lift. the back sits about 2inches lower then the front. it has 8 inch blocks in the back. seeing if anyone of you guys with rough country lifts are seeing this with your lifts. im going to get traction bars with blocks but don't know if I should go with 9in or 10in blocks? I don't want the rake look either I just want it level. what do you guys think? here is a pic of it now.
2008 f250 ccsb 4x4 lariat.. 8 inch lift, 24in fuel hostage, 40in ss m16, Arp studs, egr delete, street diesel performance down pipe, intake elbow and cac pipe, Diesel site boots, xrt pro with kem tunes, s&b intake, 5 inch exhaust, edge cts, tinted mirror lights, pioneer 8400 double din, hid headlights and fogs, two jl audio 13tw5 with rockford 1500 watt amp, jl audio door speakers and tweeters, prestige 2 way alarm and remote start.
00 f350 lariat 7.3 cc lb. (the worker)
stroker007 is offline
post #2 of 6 Old 02-15-2014, 06:36 AM
The fender cut out is 1" bigger in the front. That'll throw your eyes off big time. Park on level ground and measure to the body line, go from there as far as what the difference is then add another inch on top of the difference to then make it "level" fender cut out to fender cut out (front vs rear cut out). Only problem is rear lower corners of the fender will then be a little higher, if that makes since since rear will actually be higher (bottom of fender edge to top of tire) then from to match the fender cut out.
jayz is offline
post #3 of 6 Old 02-15-2014, 10:17 AM
I would look into custom leafs instead a huge block like that.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #4 of 6 Old 02-16-2014, 08:15 PM Thread Starter
stroker007's Avatar
got ya, thanks for the info. im not a huge fan of the lean look but I don't want the rake look either.
post #5 of 6 Old 02-16-2014, 08:24 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 115 Post(s)
Springs > blocks, and I never heard of traction bars giving lift?
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #6 of 6 Old 02-16-2014, 08:33 PM Thread Starter
stroker007's Avatar
the bars do not give lift. but they are welded to block, when you buy the bars im going with they come with a block.
