one piece driveshaft - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 51 Old 02-12-2014, 02:51 PM Thread Starter
stroken828's Avatar
Hey guys, just wondering who is running a 1 piece driveshaft under a 10" plus lift.
If yall could post pics or let me know what has or hasnt worked for yall that would be awesome
I have a 2004 6.0 on 46" MTV
stroken828 is offline
post #2 of 51 Old 02-12-2014, 09:43 PM
Take a look at moving vans, these trucks have at least 2 carrier bearings but they are rotated to be inline with the driveshaft. Shoving the CB straight down is a bad idea. Also, a one piece for that application would need to be pretty beefy (heavy) so as not to act like a jump rope when the axle starts moving.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 51 Old 02-13-2014, 06:39 AM Thread Starter
stroken828's Avatar
yea i was thinking of having my local shop build me a 4" or possibly a 5" custom drive shaft.
post #4 of 51 Old 02-13-2014, 10:35 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I wouldn't fun a 1 piece shaft, not a chance. If you break it you will probably destroy your transmission along with the shaft..
High Angle Drivline-Call Jesse at 530-877-2875 - My Buildup
Check those guys out. Their shaft has a second CV so it'll be nice and easy on the carrier bearing, and smooth. Granted they do show a 1 piece like you want and they would build one with their higher angle CV head but keeping the carrier bearing is a much smarter way to go
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 51 Old 02-13-2014, 10:42 AM Thread Starter
stroken828's Avatar
That definitely looks good ill give them a call! Thanks!
[SIGPIC][/SIGPIC
post #6 of 51 Old 02-13-2014, 10:43 AM
huck2080's Avatar
12.5 icon with one pc .. if you decide to keep a two pc go with one up offroads driveline drop ..or check out cci driveline they have a 5 aluminum with all dana spicer parts
huck2080 is offline
post #7 of 51 Old 02-13-2014, 10:46 AM Thread Starter
stroken828's Avatar
Are you saying You have a 12.5 icon with a one PC? If so are u gettin any vibration at take off speed up to 20 mph?
[SIGPIC][/SIGPIC
post #8 of 51 Old 02-13-2014, 10:56 AM
schlutzer's Avatar
Quoted: 18 Post(s)
A 1 piece can be nice and smooth but he likely has a higher angle CV to make that work.
It's just way way way safer to run a 2 piece. If it breaks down at the diff , which is the usual failure point, you'll just have 20" or so of shaft flopping around and might damage the carrier. If you have a 1 piece on my single cab that's 50" of driveshaft flopping around and it will crank the transmission case. I've been down that road
post #9 of 51 Old 02-13-2014, 10:59 AM Thread Starter
stroken828's Avatar
It's just way way way safer to run a 2 piece. If it breaks down at the difference, which is the usual failure point, you'll just have 20" or so of shaft flopping around and might damage the carrier. If you have a 1 piece on my single cab that's 50" of driveshaft flopping around and it will crank the transmission case. I've been down that road
You make a great point. My drive shaft would be in the neighborhood of 70"+
[SIGPIC][/SIGPIC
post #10 of 51 Old 02-13-2014, 11:06 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yup been there, done that
