Rubbing - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-08-2014, 05:02 PM Thread Starter
lawhadley1's Avatar
Rubbing
2012 f250 8" procomp lift 37x13.50x17 toyos. 17x9 -12mm
Tires rub every time I turn. They rub on the inner fender and on the radius arm. Is this normal for an 8" lift with 37s?
2012 F-250
pro-comp 8 inch
37x13.50r17 Toyo m/t
mayhem tank wheels 17x9.5 -12mm
SOLD 2005 f-350 4x4 crewcab short bed
Sct Livewire
Egr cooler and egr delete
airraid intake
straight pipe
35" Toyo M/T
Ranch hand front replacement bumper
custom toolbox
Bushwacker pocket flares
lawhadley1 is offline
post #2 of 4 Old 02-18-2014, 01:38 PM
I wouldn't think they would rub especially being on such a narrow wheel. They rub the radius arm because the wheel needs to be more offset to stick out further but that usually makes it rub the fender more.
I have 37s on a 4.5 inch lift and mine don't rub unless I hit a bump while turned. I did trim some inside the backside of the fenders though.
Sent from AutoGuide.com App
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
post #3 of 4 Old 02-19-2014, 05:57 AM
Quoted: 3 Post(s)
It's normal for Superduty's to rub the wheel fenders. Some people trim it, some zip tie it back, some get a heat gun and form it back for clearance. I typically trim it and zip tie it back but that's because I like wide wheels with a very negative offset.
You need spacers or correct offset wheels to get off the radius arms. Or....you could run a 3 link or 4 link kit and get rid of those beefy arms
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #4 of 4 Old 02-19-2014, 09:29 AM
Skyd Ram's Avatar
Quoted: 120 Post(s)
The fender liner rub is pretty common and can be solved by pulling back the inner lines with a few HD zip ties.
Are you sure about your wheel offset? With a 9" wheel with a negative offset I wouldn't expect it to be rubbing there.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
