Steering Stablizer question?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-07-2014, 05:41 PM Thread Starter
Recently I hit a 90 pound dog with my Excursion. I bent the pro comp steering stabilizer . Took it off and the truck drove fine , steering would come back to center when I turned , everything seemed fine. Took it to performance 4x4 to replace the one I took off. The were kind enough to replace them both. When I drove it off the lot the steering was really hard to turn and it wouldn't go back to center on its own. Took it back and they replaced the steering gear box, still no good. Took the stabilizers off and it was fine but the power steering whined bad so I fixed that and everything drove perfect. Went back to 4x4 parts and they put the latest PRO COMP Steering Stabilizers on with new mount set up and it comes back to center but not near as smooth as it should. Is this normal? should I have to help it some? I never did with the old pro comp set up ? Just curious and any input from you guys would be great.
thogue is offline
post #2 of 11 Old 02-07-2014, 05:58 PM
ZMANN's Avatar
Quoted: 1911 Post(s)
not sure whats going on with yours but i am thinking something else is still making the return to center hard and the stabilizers are just pushing it over the edge
poor dog ;-(
i have 3 stabilizers and no RTC issues
i would check the u joints I might even take the tie rod off and see if each knuckle moves easily when off the ground
the only other thing I can think of is your old procomp was toast and the new ones are just more noticeable
i run bilsteins an they are gas charged opposite direction mount so they actually push to return center
my third one is in the oem position and is just a regular dampner
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 11 Old 02-07-2014, 06:09 PM
hdodt's Avatar
If lifted or leveled, you may want to check the caster setting. Not enough caster will cause it to not return well.
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #4 of 11 Old 02-08-2014, 04:10 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 158 Post(s)
Feedback Score: 3 reviews
I bet the original one was toasted before the accident. I'm running three up front as well. Fabtech Dirt Logic and a Bilstein in the OEM position. With 35" tires it will get back to center in a controlled fashion just not "fast".
With the EX find a big parking lot, make a few full lock turns in each direction. Maybe you just need to drive it more.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #5 of 11 Old 02-08-2014, 11:17 AM Thread Starter
The ones that were replaced were only about a year old. 30k miles or less. I run 35 BFG's , I will go to a vacant lot and do what was suggested. It has always had a lift prior and never had any problems with RTC. So I don't know what the deal is. Might just not be used to the new setup.
thogue is offline
post #6 of 11 Old 02-08-2014, 11:56 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 122 Post(s)
Feedback Score: 7 reviews
they may not be the correct size for your vehicle or installed wrong. cross the part number on your stabilizer to pro comps site to make sure they are for that vehicle. then check they are mounted correctly.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #7 of 11 Old 02-08-2014, 12:31 PM Thread Starter
I will check the part # , 4x4 Parts sold the kit and installed it for me so I can only assume that its correct. ....
thogue is offline
post #8 of 11 Old 02-08-2014, 01:03 PM Thread Starter
It comes back to in a controlled return to center but not fast like you said. Is that the normal. Its a the new PRO COMP set up according to 4x4 Parts
thogue is offline
post #9 of 11 Old 02-11-2014, 01:13 PM Thread Starter
I found out that the Steering Stabilizer is the new PRO COMP PRO RUNNER SERIES, pro comp said that it wont return to center as quick as it did before because its a bigger beefer setup .....any thoughts out there on this logic?
thogue is offline
post #10 of 11 Old 02-11-2014, 01:33 PM
BBBRRRRRTTTTT
Quoted: 122 Post(s)
bigger bore, more fluid, longer lasting. handles the tires better.
