Air Helper bags - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-07-2014, 11:37 AM Thread Starter
Air Helper bags
What does everyone recommend for a 2013 f250. I really just want to be able to level truck while towing. These trucks squat a lot. Thanks in Advance.
marc1982443 is offline
post #2 of 10 Old 02-08-2014, 12:37 AM
I am wondering the same thing on my 06 King Ranch CC for the same reason. I was thinking air bags as well.
06' F 250 6.0L King Ranch CC SB
ARP Studs
OEM Gaskets
Sinister Oil Cooler
Sinister EGR Cooler
Sinister Coolant Filter
Western Traveler is offline
post #3 of 10 Old 02-08-2014, 07:27 AM
Quoted: 27 Post(s)
Both Air Lift and Firestone are the most common for pickup trucks and have great bag kits for most of the common models. I had the Air lifts on my '02 SCLB and I have the Firestones on my '13 CCLB. The bags and mounting brackets for both are of good quality and they probably took about 3-4 hours to install either pair. The gauge options and piping will take the longest to install. I had an electronic setup on the '02 and I was having pressure sensor failures which made things very difficult. On the '13, I have all manual controls with much less to fail and I am completely satisfied with them. Many others have had good and bad experiences with both methods. Regardless of the controls, bags offer the most adjustability and the smoothest ride while deflated and with an empty truck.
Sterling6.7 is offline
post #4 of 10 Old 02-08-2014, 07:34 AM
I use the air lift bags on my truck with the lines tee to the rear bumper and no troubles yet. real simple to do just time consuming. Glad i did it wont ever be without again.
big eddie is offline
post #5 of 10 Old 02-08-2014, 07:44 AM Thread Starter
Thank you for the responses. I looked at the Firestone system last night. I think I'm gonna go with it. I will also be getting the viair 480cc compressor with an 8 gallon tank.
post #6 of 10 Old 02-08-2014, 08:51 AM
Heavy_GD's Avatar
Quoted: 1566 Post(s)
Feedback Score: 3 reviews
Is your truck lifted?
I prefer an "over the leaf" design versus and over the axle design... just my
GD
Heavy_GD is offline
post #7 of 10 Old 02-08-2014, 09:27 AM
fordtrix's Avatar
I have a 2013 f250 with Ride Rites. I tow a 15k lb 5th wheel a few times a year which is why I got them. Doesn't squat at all with them inflated to half their psi range.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #8 of 10 Old 02-08-2014, 10:00 AM Thread Starter
Heavy _GD truck is not lifted yet. I will be doing a 4 inch lift in the future.
post #9 of 10 Old 02-08-2014, 10:18 AM
Heavy GD. No lift, none in the future. Is there a clearance problem or just more difficult install without a lift?
I had been looking at the no drill kit which is an axle mount.
Thanks
ARP Studs
OEM Gaskets
Sinister Oil Cooler
Sinister EGR Cooler
post #10 of 10 Old 02-08-2014, 10:35 AM
Heavy_GD's Avatar
The issue I have with my lift is the "blocks" they send you to stack the bags on.
Anything under 8 inches you are fine
GD
Heavy_GD is offline
