POPPING IN FRONT LEFT WHEN TURNING - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-07-2014, 06:06 AM Thread Starter
I Have a lifted 2013. 6 Inch lift with 37s and 22s. When turning left i am getting a popping noise in the front left and can feel it throught the floorboard, I can also feel it when going over bumps in the fron left. It hardly ever does it when its warm outside but when its cold it does it non stop and when hitting any bump in the road. I have looked at everything underneath and i cant find anything. Any ideas? Thanks for any input
LIFTED13 is offline
post #2 of 8 Old 02-07-2014, 08:59 AM
Skyd Ram's Avatar
Quoted: 128 Post(s)
It's more that likely the track bar bolt or the track bar drop bracket. I would go back and retorque all that hardware to spec. The track bar bolt on the frame side needs to be torqued to 406 ft/lbs.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #3 of 8 Old 02-08-2014, 03:44 PM
tebeller's Avatar
I have the exact same issue and have ever since I installed my lift. I could not find a shop that could measure 406 ft lbs so I went to a Jeep shop where they had a five foot cheater bar and they went over all of the nuts and bolts that I messed with during the install. The pop got better for a few thousand miles but is back in force now. I feel your pain man!
tebeller is offline
post #4 of 8 Old 02-08-2014, 03:49 PM
montana6.0's Avatar
Definitely track bar bolt mine is popping right now also very annoying.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #5 of 8 Old 02-08-2014, 03:57 PM
WoodBoy's Avatar
Mine also does it at random times but mainly when coming to a stop or going over a speed bump slow, etc.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #6 of 8 Old 02-08-2014, 04:11 PM
If you rule out the track bar, I had a ball joint in a 1/2 ton truck that would do that... Sure enough, with the tire off the ground you could move the tire in and out the ball joint was so toast...
TxOutlaw is offline
post #7 of 8 Old 02-26-2014, 11:53 PM
txwayno's Avatar
Damn glad I found this thread. My truck with 6" lift is doing the exact same thing. Was thinking ball joint but will now check the track bar bolts. Thanks!
txwayno is offline
post #8 of 8 Old 02-27-2014, 04:50 AM
Quoted: 3 Post(s)
Best thing to do is to put a bottlejack or floor jack under the end of a cheater pipe or breaker bar. Use this method to turn the bolt once you can no longer do it yourself.
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
