Leveling blocks or new coils - Ford Powerstroke Diesel Forum
post #1 of 18 Old 02-03-2014, 06:52 PM Thread Starter
I have been searching and reading for about 2 days straight and said screw it, I'll just ask. I have a 2006 F350 4x4. I have read enough to know that with a 2.5" front level I can run 285/75/18 on my stock wheels. My question is, do I go with just the blocks or are the new coils better? What about shocks? My truck has 200K on it and I have no idea when the shocks were last replaced. It drives good but sometimes seems to get a little loose over bumps, maybe shocks are junk, not sure. I'm not afraid to spend the money on good parts but in the end I just want to put the new tires on my 18's this spring. I just had the front end lined up last year after I put on a new steering box. Any recommendations of parts that work well together??
2006 F250 Lariat Bulletproofed
2006 F350 XLT bulletproofed SOLD
1983 Mustang GT 410/C4 SOLD
MustangSmitty is offline
post #2 of 18 Old 02-05-2014, 02:08 PM Thread Starter
Nobody has any opinion on new springs or just the blocks? Alrighty then, guess I'll do it my my..lol.
post #3 of 18 Old 02-05-2014, 02:11 PM
New coils will ride better than adding a spacer. On the rear a mini pack would help with the ride. Shocks can be had relatively inexpensively so I would defiantly change those.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #4 of 18 Old 02-06-2014, 05:38 AM Thread Starter
Brett
4 new shocks for sure. now on the coils though to get the lift are they a progressive rate or just a longer coil? If I have read correctly the quality kits will come with the shims and what not for the alignment?
post #5 of 18 Old 02-06-2014, 09:33 PM
Quoted: 35 Post(s)
Most of the lift coils are in fact progressive. Like you stated, definitely four new shocks! Most of the kits will come with the proper castor cams to correct the alignment. If you piece the kit together, be sure to order them as well.
Sent from AutoGuide.com App
Free shipping on Carli Suspension to the US and Canada!
424-241-3252
CJCOffRoad is offline
post #6 of 18 Old 02-07-2014, 03:31 AM Thread Starter
Are the progressive springs going to be a rougher ride than stock?
post #7 of 18 Old 02-07-2014, 05:35 AM
Quoted: 35 Post(s)
No the progressive coils are meant to rode smoother than stock. The theory of the progressive coils is that the first stage is way lighter for the small bumps etc, and then they progress to the heavier rate to keep the trick controlled and up right. The main idea is they are smooth over smaller dips and bumps while keeping the truck from riding sloppy.
424-241-3252
post #8 of 18 Old 02-07-2014, 06:17 AM Thread Starter
Do you have any recommendations on what brand or manufacturer to go with?
post #9 of 18 Old 02-07-2014, 07:04 AM
Quoted: 35 Post(s)
I would check out the Carli suspension systems. Their ride quality is excellent, especially when you look into their different shock packages! Feel free to give us a call if you have any questions about the specifics.
424-241-3252
post #10 of 18 Old 02-07-2014, 07:43 AM Thread Starter
Thanks for your help.
