Icon adjustable track bar - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 52 Old 02-02-2014, 05:45 PM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
Anyone know the measurement for the track bar on the 7" icon lifts. My front axle looks a little off center toward the passenger side maybe an inch or so.
also was re centering my steering wheel and seem to have ran out of adjustments there also. i was rolling it forward , which turns the wheel to the left. had to go half a turn to get the steering wheel to center, but came up short about 2 inches....do i gotta go the other way all the way around or is there something else i need to do.
Big_Smokey is offline
post #2 of 52 Old 02-03-2014, 11:14 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
Feedback Score: 3 reviews
I could measure mine but it's on 5.5"-6" up front. It could give you an idea at least. Did you run out of adjustment thread?? It might be the result of the trac bar length.
I recall being told you need to remove the sway bar end links and trac bar. Lift the truck till the front suspension is at full droop. The axle should align under the truck due to the shocks and radius arms. Then you lower the truck down till you are 3-4" high from full rest. Install the trac bar and let the truck all the way down. Check side-to-side. Then install the sway bar end links.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 52 Old 02-03-2014, 02:58 PM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
Yah i had to drop them to install the drop brackets, but its possible that i put them back on too soon....Ill fart around with it again when it warms back up. Too cold and snowy for me now.
post #4 of 52 Old 02-19-2014, 05:04 AM
if its offcenter towards the passenger side you need to make the track bar shorter. Every adjustment to the track bar will change where you steering wheel is when your wheels are straight (by changing the distance from the steering box to the passenger side knuckle).
I wouldn't bother getting the steering wheel straight untill you get your axle centered under your truck at ride height. The icon bar makes it easy, shouldn't need to disconnect anything, just undo the clamps on the adjuster, adjust it, tighten them back up. Icon uses the same bar for 2.5-7" lift, so im guessing at 7" you would be farther out on the threads (not unsafely far, but farther than a 2.5 or 4.5" lift would be)
bringing the axle back to center will gain you that 1" on the steering adjustment and might put you back in range, though i don't pretend to know anything about the suspension / steering geometry on 7" lift
06 CCSB f250
4.5" icon Lift & 35x12.5r18 trail grapplers
n-fab steps, MRBP 5" exhaust
SCT running looney tune
housew is offline
post #5 of 52 Old 02-19-2014, 05:06 AM
also i found this thread because i have this bar, and the frame side joint / bushing seems to be spanked. (if i have a friend cut the wheel i can watch it move ~1/4 of an inch).
has anyone had this problem. does this joint need to be preloaded with crazy amounts of torque on the through bolt? was the bolt / hole in the frame supposed to be enlarged by the PO when they installed the bar and it wasn't? or do i just need to replace the joint? ($125 from icon)
06 CCSB f250
housew is offline
post #6 of 52 Old 02-21-2014, 04:45 AM
all figured out. The stock bolt was the issue, the joint was fine.
stock bolt was supposed to be 20mmd, and it was worn down around 18mm (giving it slop in the frame bracket, and around the end). Also the threads were corroded so the torque value wouldn't have cooresponded to as much squeeze as the torque value would normall equal.
either way, a new m20x100mm bolt, nut, and proper torque and everything is GREAT. Just updating so people didn't get a false sence of icons quality.
their customer service is excellent as well. My bar is actually the donahue racing one and they verified that it hasn't changed and the part number 64032 (upgraded end) would bolt right in. They have been very helpfull to me, especially since i bought the truck with an unknown lift (that turned out to be a 4.5" donahue racing) and im figuring it all out with their help.
06 CCSB f250
housew is offline
post #7 of 52 Old 02-27-2014, 05:13 PM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
Anybody know if the 7" icon is made to just use the stock track bar? there is a drop bracket i put on, so i figure its for that purpose. just double checking.
post #8 of 52 Old 02-28-2014, 08:22 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
That is what I have on my truck now along with the stock track bar but the frame end is pretty sloppy at the bolt. The axle seems to be pretty well centered under the truck but I just ordered a new ball joint and a Pure Performance adjustable track bar. Its a solid 1.625 shaft and I know the axle will stay put. The oem track bar is a bit light as far as Im concerned, 38/15.50/18 tires certainly don't help.
So if it's centered and your not getting the death wobble run it till you wear it down. Because you will, I'm only at 88,000 and it's been done longer then I thought.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #9 of 52 Old 03-01-2014, 01:59 AM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
Its a brand new OEM one. I actually had it replaced due to death wobble and ball joints. Under warranty! Its just laying around, so i thought about using it and then later doing something like you suggested. actually think that i need to replace that ball joint as well.
post #10 of 52 Old 03-01-2014, 05:57 AM
If you replace the frame end mount and not the pitman arm (should need a bigger drop one) you should get horrendous bump steer. I can't believe a company (especially as good as icon) would be endorsing that
06 CCSB f250
housew is offline
