Abnormal front tire wear - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-01-2014, 12:01 PM Thread Starter
Ok, as you can see I have a 2wd dually. The front tires wear excessively on the outside edges about 1.5" toward the inside. It's bad enough that the steel cord is shining thru when the rest of the tire has almost new tread. It seems to happen on the right more than the left. I assume the camber is off by a ton. What do you guys recommend as a starting point?
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #2 of 11 Old 02-01-2014, 08:05 PM Thread Starter
No one interested in commenting?
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #3 of 11 Old 02-01-2014, 08:06 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
ball joint good? Drag links? Tie rod ends?
2000-7.3L is offline
post #4 of 11 Old 02-01-2014, 08:08 PM Thread Starter
185000 miles. Drag link bushings look ok. Ball joints and pivot points look good too.
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #5 of 11 Old 02-01-2014, 08:09 PM Thread Starter
2nd owner. No bumps or bruises either
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #6 of 11 Old 02-01-2014, 08:11 PM
2000-7.3L's Avatar
Now when you jack it up, everything feel tight!
My guess would be ball joints need to be replaced or the drag link, One cant simply look at them and say they look ok. Need to find out if there is play when you check it left to right and up and down
post #7 of 11 Old 02-01-2014, 08:13 PM Thread Starter
Good point. I will jack and do the looseness tests in the morn.
Thanks
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #8 of 11 Old 02-01-2014, 08:15 PM
2000-7.3L's Avatar
Thanks
Not a problem
Check back, also how are the wheel bearings?
Sent from AutoGuide.com App
post #9 of 11 Old 02-01-2014, 08:16 PM Thread Starter
Never considered wheel bearings. Steer ability is ok and no pulling.
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #10 of 11 Old 02-02-2014, 04:11 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Shocks check out??
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
