Leveling kit instal - Ford Powerstroke Diesel Forum
post #1 of 41 Old 01-30-2014, 11:14 AM Thread Starter
Leveling kit instal
Installing my 2.5" icon coils and alignment cams with PMF adjustable track bar next week. Seems pretty straightforward, just curious if there's any out of the ordinary tools I may need to get beforehand?
Truck is 2005 F250 FX4.
Sent from AutoGuide.com App
Alpha Male is offline
post #2 of 41 Old 01-31-2014, 01:19 PM
fordtrix's Avatar
I needed a spring compressor on my 2013 leveling kit install. I dropped the axle wayyyyy down and it still wasn't enough with out compressing them a ton.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #3 of 41 Old 02-01-2014, 04:10 AM Thread Starter
Really? I read through the instructions and it didn't say anything about having to use a spring compressor. I guess I'll try it and then if I end up needing one I'll go buy one. I wonder if O'reillys or anyone rents them out?
post #4 of 41 Old 02-01-2014, 04:33 AM
Java's Avatar
I did an icon leveling kit on a buddies 2012 a couple of weeks ago, we didn't need a spring compressor at all. It was really close though.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #5 of 41 Old 02-01-2014, 09:32 AM
Curious, what are you doing with your old springs and rubber doughnuts?
If they are in decent shape, I may be interested in buying them from you.
You should be able to get a set of compressors at O'Reillys or Autozone or Advance, no problem. I think it all depends on how high you can get the truck or how low you can get the axle.
Your spring is probably around 16" compressed and the leveling spring is around 24" sitting in the box? Its just a game of inches played with big jack stands. Might want to try to do one side at a time, unless you have access to a lift...
Banger is offline
post #6 of 41 Old 02-01-2014, 02:23 PM Thread Starter
I have no idea what I'll do with them really, the springs have about 180k on them but as far as I can tell they're still working well. And what you mean by runner doughnuts?
I should have access to some pretty tall jack stands so hopefully I won't need a compressor. Any of y'all installed the alignment cams?
post #7 of 41 Old 02-04-2014, 06:39 PM
I use a bottle jack in between the axle and the frame. Makes the coil install a breeze.
sw99 is offline
post #8 of 41 Old 02-04-2014, 07:11 PM
I installed my 4" lift w/o a spring compressor. It'll drop down!
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #9 of 41 Old 02-04-2014, 07:16 PM
kirbybc12's Avatar
A torque wrench that will torque down to 404 ft lbs for the frame end of the track bar. I couldn't find an affordable one or one to borrow so I had the alignment shop torque it down, also a front end service kit (ball joint puller) for the other end of the track bar. Everything else is pretty much straightforward: ratchets, breaker bar, etc.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #10 of 41 Old 02-05-2014, 08:44 AM
Skyd Ram's Avatar
Quoted: 149 Post(s)
You can always loosen the frame side bolts on the radius arms and it should allow for some more droop.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
