Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 10-15-2008, 06:47 PM
Mudracer80 Mudracer80 is offline
ext. cab rear springs on a crew cab???
I have a 4" lift that came off of a 01 ext cab 3/4 ton f250, it came with the OEM rear springs with the pro-comp add a leaf all ready installed on them.
I was woundering if it would be ok to put them on my 3/4 ton Crew cab? OR are the crew cab rear springs stiffer because of the added wieght?
Old 10-15-2008, 06:49 PM
DCSpecial DCSpecial is offline
Supporting Vendor
Spring capacity varies based on suspension package the truck was equipped with.
99-07 rears are the same length and can be interchanged.
08s are longer.
Old 10-16-2008, 08:36 AM
Is there anyway to tell what package springs they are?
Old 10-16-2008, 08:54 AM
caryt caryt is offline
They will be fine. The code is stamped on the spring.
