Lift Kit question (05 Harley CCSB) - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-28-2014, 08:44 PM Thread Starter
Did plenty of searches and I think my question is a little bit different.
I have a 2005 Harley F350 CCSB PSD and the truck is basically stock. What I am looking to do is raise my truck up some while keeping the cost down. I plow with this truck ( My previous truck which I plowed with had a 6" lift so I am not worried about going up and plowing but don't need to go that high)
In the summer I plan to run some 22x11 wheels and want to have a descent tire that doesn't look like a rubber band!
So my question is what is the best route to go for the cheapest money while not totally KILLING ride quality and my wallet?
Believe me I understand im not spending 3k on a really nice suspension setup to ride perfect, that's not what I am trying to accomplish.
I was thinking maybe a 4" lift kit? I have seen some for around 1k and under.
Is there a leveling kit that will bring the front up maybe 3.5 and the rear 2.5 or something? Like I said my previous truck had a 6" which was already done when I got it so I am not firmiliar with the capabilities of a leveling kit vs lift kit other then it seems leveling is just the front of the truck....
Can anyone recommend a complete kit that will raise my truck between 3-4" that is not super expensive and has a descent ride?
Thanks in advance guys
2003 PSD 6.0 ECSB
2005 F350 Harley Davidson PSD
KillerMike is offline
post #2 of 6 Old 01-29-2014, 03:31 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Baller on a budget...nice. Get away from the 22" wheels for one. Any wheel under 20" would work fine. What's super expensive?? I'd spend $2k for a kit (new, retail) if it were my ride.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 6 Old 01-29-2014, 03:53 PM
Raul@Stealth Automotive's Avatar
you could go with like a 4" procomp kit. its prob going to be your best option... a leveling kit only raises the front not the rear
Raul@Stealth Automotive is offline
post #4 of 6 Old 01-29-2014, 06:23 PM Thread Starter
Ive seen many leveling kits with the rear lifted also, with blocks....
2003 PSD 6.0 ECSB
post #5 of 6 Old 01-30-2014, 04:16 AM
jetjock15's Avatar
Quoted: 110 Post(s)
Blocks and coil spacer get you baller on a budget, 35s on 22s look rad, I don't know about 33s.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #6 of 6 Old 01-30-2014, 08:07 AM
Skyd Ram's Avatar
Quoted: 117 Post(s)
That will depend on what you mean by decent ride. Ride better than stock or just as good as stock? You are already going to take hit in the ride dept with those wheels. Assuming that you want to stick around 4" of lift you will probably have to stick with a 33-34" tire on those wheels. That leaves you with very short and very stiff sidewalls.
You can get into a high quality kit like the Pure Performance 4" X-Factor and a set of Bilsteins for around $1500.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
