OUO traction bars - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 20 Old 01-28-2014, 04:27 PM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
OUO traction bars
So i finished up my 7" icon a couple weeks ago and have been putting off putting in the OUO adjustable traction bars.. I have a CCSB and i was just wondering what lengths you were using when installing these. Obviously i guess if you dont have the same setup as me it may be different. Im just nervous i guess since i have one shot at setting these up once i install the crush sleeves.
Thanks.....
Big_Smokey is offline
post #2 of 20 Old 01-28-2014, 04:31 PM
F250SixOH's Avatar
I'll start off by saying that I don't have them but I would assume that the longer the bars, the better the arc that the axle travels will be as well as less binding.
F250SixOH is offline
post #3 of 20 Old 01-28-2014, 04:55 PM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
Yah, I'm learning as I go about these, as I've never installed or owned a set. Thanks for the reply
post #4 of 20 Old 01-29-2014, 02:35 AM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
Anybody else with some knowledge here.
post #5 of 20 Old 01-29-2014, 05:00 AM
Java's Avatar
What year is your truck? On the 2011+ the longer you can mount them the better.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #6 of 20 Old 01-29-2014, 09:28 AM
huck2080's Avatar
who did you buy them from my trans bracket came with way detailed instructions .. you could call truck toyz they could tell you
huck2080 is offline
post #7 of 20 Old 01-29-2014, 02:03 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
What crush sleeve do u speak of?
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #8 of 20 Old 01-29-2014, 02:28 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 141 Post(s)
Feedback Score: 3 reviews
You need to temporarily setup the forward mount. See if there are any clearance issues while test fitting the bars. The bars themselves will not flex a ton but you don't want anything making contact. If you find issues somewhere in your placement you need to relocate the forward mounts.
Remember to consider ANY future work you may be doing. You don't want to block a simple task and make it more time consuming.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 20 Old 01-29-2014, 03:10 PM Thread Starter
Big_Smokey's Avatar
Quoted: 9 Post(s)
The adjustable bars have a crush sleeve that goes thru the two bars once u get everything set and the hole drilled in the bars .
Truck is an 09.
Right now where I am wanting to mount them is next to the rear cab mount. It puts the bar almost parallel to driveshaft. Wasn't trying to do this but that's what it is looking like.
post #10 of 20 Old 01-30-2014, 11:19 AM
layson's Avatar
Quoted: 83 Post(s)
They should have came with a real nice set of instructions? I know with my LBCC there was pretty much only one real good location to mount them, which was right where the frame changes geometry.
Don't worry about trying to get it to match the driveline. That will not matter one bit in how these work.
Where did you buy them from? You should be able to give them a call. Or just give Dave a call. He will help you out.
huck2080 likes this.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
