lift kit help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-27-2014, 08:08 PM Thread Starter
Quoted: 2 Post(s)
lift kit help
I have a 06 ps sd 6.0 4x4 its has a factory tapered block in the rear im about to put a 4inch block in and take out the factory two in block. do I have to get a tapered block or no.my truck is a regular cab long bed 4x4 6.0
89ezgo is offline
post #2 of 8 Old 01-28-2014, 08:42 AM
Best to get the factory F350 blocks, they are 4" and have the bump stop built in.
sw99 is offline
post #3 of 8 Old 01-28-2014, 11:21 AM
Check out Newton's Lifts online. They will know exactly what you need. Blocks and UBolts for our truck at $140, IIRC...
TxOutlaw is offline
post #4 of 8 Old 01-28-2014, 03:55 PM Thread Starter
Quoted: 2 Post(s)
the f350 block does it matter a year? and does it have be a diesel or a 4x4. im sure I can find some are they tapered or flat. and can I just swap them in
89ezgo is offline
post #5 of 8 Old 01-28-2014, 04:21 PM
Yeah, you can swap the f350 block in an f250... I would probably stay within your year range to be safe. For 4wd, they are 3.5" compared to our 2". Might still need new Ubolts.
TxOutlaw is offline
post #6 of 8 Old 01-28-2014, 07:28 PM
I have this kit - http://www.amazon.com/Pro-Comp-62244-Suspension-Block/dp/B005F0M828
No taper though. You can always add a steel shim to the leaf pack if you need some angle. Some folks shim the carrier bearing if you have one.
sw99 is offline
post #7 of 8 Old 01-29-2014, 08:58 AM Thread Starter
Quoted: 2 Post(s)
mine a 06 are these f350 blocks tapered because mine are for sure
89ezgo is offline
post #8 of 8 Old 01-29-2014, 05:56 PM
Maybe try and track down an F350 RCLB part number from the dealer and ask them if it's tapered.
sw99 is offline
