Steering wheel is off - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-25-2014, 12:17 PM Thread Starter
fiveton's Avatar
Hey guy's does anyone know how to re-position the steering wheel on my 06 F350. My steering wheel bar is off 90 degrees to the left the the bar is at 12 and 6 instead of 3 and 9 . The wheels are straight and the truck is tracking straight and even ?
Thanks
Fiveton
fiveton is offline
post #2 of 10 Old 01-25-2014, 12:25 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1012 Post(s)
Feedback Score: 6 reviews
Yeah it's not very hard at all. You can adjust the drag link. Park your truck with your wheels turned straight. Have key on, engine off and E-brake on. Loosen the nuts on the retaining sleeve of the drag link and adjust the sleeve, by turning it up or down depending on which way your wheel needs to be adjusted, until your steering wheel is straight. If I remember correctly, turning the sleeve upwards moves the wheel to the right and and down moves it to the left, but I could be wrong. I am pretty sure the nuts are a 14mm or 15mm, it has been awhile since I did mine. It's easier with someone inside telling you when the steering wheel is straight.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
The Following User Says Thank You to Rattlesnake18 For This Useful Post:
fiveton (01-25-2014)
post #3 of 10 Old 01-25-2014, 12:39 PM
mcdaniel1991's Avatar
Tightening turns the steering right loosen to turn it left. You have to remove the piece on the right to be able to turn it.
2006 F-250 XLT FX4 PSD 185,000 Mi
Innovative and Gearhead tunes, BPD 58v 6 Phase FICM,
Updated Blue spring, Dummy plugs and STC fitting, Straight exhaust, Zoodad, Sinister EGR/COOLER delete, Oil cooler Rerouted, Sinister Coolant Filter, Mobile 1 5w 30, Edge CTS Monitor, Isspro- FP, EGT, VDC and Coolant PSI. Soon to be under the knife for studs, lifters, rockers, pushrods and new seals.
mcdaniel1991 is offline
The Following User Says Thank You to mcdaniel1991 For This Useful Post:
post #4 of 10 Old 01-25-2014, 12:41 PM
RIP Cam!
I would also suggest that after you adjust the sleeve and tighten the nuts up, go drive it around a little and then come back and readjust it again as needed. I had to do mine twice to get it just where I wanted it.
post #5 of 10 Old 01-25-2014, 03:48 PM
Is the nut on the right side of the sleeve the one to tighten? I need to do mine as well.
TxOutlaw is offline
The Following User Says Thank You to TxOutlaw For This Useful Post:
post #6 of 10 Old 01-25-2014, 04:00 PM
You remove the clamp on the right side and loosen the two bolts in the middle then twist that piece in the middle that you just loosened...Hope this helps.
WD-40 and channel locks will be your friend here.
post #7 of 10 Old 01-26-2014, 06:12 AM
F250SixOH's Avatar
Might want to let some penetrating oil sit on there for the night first
F250SixOH is offline
The Following User Says Thank You to F250SixOH For This Useful Post:
fiveton (01-26-2014)
post #8 of 10 Old 01-26-2014, 09:18 AM Thread Starter
fiveton's Avatar
Ok so I decided to do the adjustment today loosened both the clamp bolts up, I don't have anything else on that drag link to loosen. I tried to turn the sleeve but it won't move. I wonder do I have to put it up on jack stands or not to take the pressure off ?
Thanks
Fiveton
fiveton is offline
post #9 of 10 Old 01-26-2014, 09:41 AM
It is going to be rusted together, you will have to work it back and forth to get it broken loose. Soak it in the center with wd-40 then just grip it with channel locks turn it.
fiveton (01-27-2014)
post #10 of 10 Old 01-30-2014, 12:39 PM Thread Starter
fiveton's Avatar
Ok so I decided to fix the steering wheel problem today when I got home from work and I when I got out of the truck I notice the steering wheel is straightened out.What is going on here I can't seem to find anything loose ?
Fiveton
fiveton is offline
