What size coilovers for 6" lift - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-25-2014, 11:58 AM Thread Starter
Installing a 6" lift and I am trying to find out what coilivers to run? What lenght of coilovers are you using? How do you like your ride?
dezert7 is offline
post #2 of 4 Old 01-26-2014, 08:14 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Depends how your going to mount them? 6-8" travel king depending on the mount. The valving and spring rate all variable so other folk's reviews won't be as equivalent as comparing like bilstein 5100s for example. Get low compression high rebound valving with a 550 spring or something close, you will love it
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 4 Old 01-26-2014, 11:42 AM Thread Starter
Thanks. How do you like the king shocks? I was thinking either going with fox or king.
dezert7 is offline
post #4 of 4 Old 01-27-2014, 11:42 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
8" would work fine. Look at Pure Performance kits we can get you one setup for a 6" lift.
PM me if I can help.
CT Performance, Inc. is offline
