how much lift do i need - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-24-2014, 02:33 PM Thread Starter
I have a 2006 6.0 how much lift do i need to run a set of 37 13 17's super swampers I bought from my cousin for 300 a piece with wheels just wondering how much lift I need to not rub thanks
066leaker is offline
post #2 of 9 Old 01-24-2014, 03:20 PM
huck2080's Avatar
at the very least six inch's
huck2080 is offline
post #3 of 9 Old 01-24-2014, 03:23 PM Thread Starter
How much do u will fit with a 4.5 from rough country cause I can buy a used one for 200 its been off truck for 6 months and was only on truck for 2 weeks tell truck was sold
post #4 of 9 Old 01-24-2014, 11:10 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Like Huck said you need at least 6" of lift for 37" tires. You will bend fenders with 4-1/2 for sure.
A 6" lift deals with much more then a 4-1/2.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #5 of 9 Old 01-24-2014, 11:52 PM Thread Starter
Dam I don't want to go that high
post #6 of 9 Old 01-25-2014, 02:29 AM
huck2080's Avatar
would you be willing to cut your fenders ?
huck2080 is offline
post #7 of 9 Old 01-25-2014, 02:47 AM Thread Starter
No I don't want to cut fenders
post #8 of 9 Old 01-25-2014, 07:03 AM
jetjock15's Avatar
Quoted: 110 Post(s)
All depends on the wheels you run. Wider wheels with less backspace (push tire out) cause more scrub radius turning, thus need more lift. Of you run 12" wide wheels with -44 offset you need 8 inches. If you run those 37s on OEM wheels you could probably do 4.5" lift and space bumper forward 3/4".
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #9 of 9 Old 01-25-2014, 07:29 AM Thread Starter
Wheels are 10 inches wide I don't know back spacing but I'll figure it out I'm just gonna get a 6 inch lift
