Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
  #11 (permalink)
Old 10-15-2008, 04:48 PM
mrgrimm mrgrimm is offline
The shop that installed the lift should have probably suggested an alignment, which would straighten your steering wheel...on a straight axle vehicle not much changes with a lift but is still probably a good idea since I'm sure you have some new tires on there as well that you don't want wearing funny.
  #12 (permalink)
Old 10-27-2009, 08:20 AM
Jimmy 6.0 Jimmy 6.0 is offline
Wouldn't getting an ailinment fix this without doing that kind of adjusting? Doing it the way that was decribe, would it change something on the suspension other then the steering wheel?
  #13 (permalink)
Old 10-27-2009, 04:29 PM
Powerstroke W/smoke Powerstroke W/smoke is offline
i did it the way described and it only required a half turn and my wheel is straight. i did not notice any other changes.
  #14 (permalink)
Old 10-28-2009, 05:11 AM
My steering wheel is between the 10 and 11 o'clock postion to drive straight. How much do you think that it would take? I am new to this diesel thing. I have only owned the truck about a week and a half, so there is alot to learn about this truck.
  #15 (permalink)
Old 10-28-2009, 07:18 AM
rod.10853 rod.10853 is offline
When you get up under there you'll see that all you're
doing is lengthening or shortening the drag link when you
are making the adjustment. In your case, it sounds like it
will take maybe a 1/4 turn to change the drag link length
to what will position your steering wheel correctly. But,
you won't really know until you just start turning to make
the adjustment.
  #16 (permalink)
Old 10-28-2009, 03:05 PM
Smile
the adjustment.
Thanks, I will give it a try here in about 30 mins when i get off work.
  #17 (permalink)
Old 10-28-2009, 04:59 PM
try to have someone sitting in the driver seat cause it makes it easier
  #18 (permalink)
Old 10-28-2009, 05:50 PM
Didnt get a chance to make an attempt. Starting raining and i dont have a gargage to work in right now. Hopefully I can do it tomorrow if it is not to cold outside.
  #19 (permalink)
Old 10-28-2009, 09:07 PM
good luck Jimmy. it's not that bad, and it feels so much better when it is fixed
