Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
  #11 (permalink)
Old 10-08-2008, 07:49 PM
2005F250 2005F250 is offline
Originally Posted by choctaw View Post
I wonder why mine didn't do that.
It's less noticable with stock tires/wheels.
  #12 (permalink)
Old 10-08-2008, 07:50 PM
Evil Eye Evil Eye is offline
Slacker Mod
Mine's also equal on both sides. It wanders all over like crazy, but my axle is centered.
  #13 (permalink)
Old 10-08-2008, 07:52 PM
DCSpecial DCSpecial is offline
Supporting Vendor
Do you have caster cams installed with the leveling kit?
  #14 (permalink)
Old 10-08-2008, 07:53 PM
choctaw choctaw is offline
I'm #1 in the #2 Business
What an assumption on your part.
  #15 (permalink)
Old 10-08-2008, 07:54 PM
What you mean?
  #16 (permalink)
Old 10-08-2008, 07:57 PM
Supporting Vendor
As for how or why the trac bar pulls the axle over to the driver's side....here's a little experiment that you can do if you want.
Stand up
Go Close to a wall.
Extend your arm straight out so that your finger tips are just barely touching the wall.
While, remaining in place, lower your arm 3".
Your fingers are no longer touching the wall, since your arm is a fixed length and moves in an arc as it goes up and down.
Just like a trac bar.
Your shoulder would be the upper mount at the frame and your hand/fingers the mount at the axle.
Obviously the frame isn't going anywhere, but the axle can be pulled over under the truck.
  #17 (permalink)
Slacker Mod
Nope, but saw your post the other day and am strongly considering them. Will it be that much of a difference? I love the look of my truck but hate the leveling kit due to the wandering.
  #18 (permalink)
Old 10-08-2008, 08:01 PM
Supporting Vendor
It's a 2.25* postive change in caster with the cams.
The 05+ trucks don't run much caster stock and installing a leveling kit w/o cams gives you a more negative caster reading.
Too negative (too close to zero or an actual negative degree) on the SDs will cause wandering.
Wheel Alignment A Short Course
Stock cam vs. the cam that comes with the Icon 2.5":
  #19 (permalink)
Old 10-08-2008, 08:03 PM
Just make sure your tires will clear before you drive off after installing the cams, if you do. I put them on my truck got all done lowered the front and turned the wheel while in the shop still and tire hit the fender metal, not liner but the painted metal. Didn't even make it out of the shop before I put the stock cams back in. 8 hours of wasted time and $500 later I was on my way ($100 for the cams but while the truck was apart I also went and bought the Bilstein leveling kit because I wanted the spacers gone)
  #20 (permalink)
Old 10-08-2008, 08:32 PM
Supporting Vendor
With the upper ball joint being moved back such a small amount it's hard to imagine that you rubbed sheet metal with them, but rub nothing now.
