remove rear block..... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-20-2014, 01:44 PM Thread Starter
Quoted: 2 Post(s)
Is it okay to remove the factory 2inch blocks i have total 5inchs of lift in the rear slock 2inch block with a 3inch block ontop..thing is i want to go down 1inch in the rear so could i just pull out the factory and the 3inch and put one solid 4inch block in?
89ezgo is offline
post #2 of 11 Old 01-21-2014, 07:07 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 115 Post(s)
Feedback Score: 3 reviews
Yes. Putting one solid 4" block will work just fine.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 11 Old 01-21-2014, 07:08 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
just make sure the u bolts have the correct length
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 11 Old 01-21-2014, 10:21 AM Thread Starter
Quoted: 2 Post(s)
so I went to a local 4x4 shop today to pick up set of 4inch tapered blocks. my blocks that are on the truck now are tapered and they wanted to sell me a non tapered...I don't see why id switch them to a non tapered so I went head an got the tapered ones.. how much are they suppost to be off the 4inch blocks I just got read 4inch and 3 1/2
89ezgo is offline
post #5 of 11 Old 01-21-2014, 05:58 PM Thread Starter
Quoted: 2 Post(s)
89ezgo is offline
post #6 of 11 Old 01-21-2014, 06:46 PM
So the tapered 4" block actual height is 3.5?? I am not sure if actual block measurements = true raise height but I know the front coil spacers can measure shorter than they raise. Maybe someone can be more informative.
TxOutlaw is offline
post #7 of 11 Old 01-21-2014, 07:03 PM
Quoted: 784 Post(s)
Oem Rear f350 block IIRC is 3 5/8"
Of course you can buy whatever an aftermarket sells.
Have you ever had feelings for a nun??? "Nacho Libre"
Corey@CNCFAB is offline
post #8 of 11 Old 01-22-2014, 05:10 PM
When I went from blocks to lift springs, I trimmed the u-bolts down and cut new threads into them. We did the same thing when we lowered a friend's F350 from 8 to 4.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 11 Old 01-23-2014, 12:08 PM Thread Starter
Quoted: 2 Post(s)
well mine are blocks in the rear total of 5inchs they are tapered messure 5inch on one side and 4 1/2 on the other. I have a set of single 4inch tapered locks I want to swap in so I can lower the rear down 1inch can I just put them in with out knocking any angles off. im drive a 06 sp 6.0 reg cab long bed. the new blocks 4inch blocks rear 4inch and 3 1/2
89ezgo is offline
post #10 of 11 Old 01-24-2014, 08:45 AM
Measure the blocks where the alignment pin is to get a better idea of how tall each block really is. Front and rear measurements are more for figuring taper.
Karls03 is offline
