lifting rear end - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-16-2014, 06:44 PM Thread Starter
lifting rear end
The truck in my sig has a 2 inch leveling kit so I could fit 35's. When I pull a trailer it sags pretty bad so I wanna add 2 inches or so to the rear. Just wondering what you guys recommend? I was thinking of just adding blocks but figured id get your opinions and/or see if you fellas had a better suggestion. thanks!
2000 7.3 regularcab longbox 4x4, TS 6-position, line-x on rockers, 35/12.50/16 procomp extreme all-terrains on black moto metal 951's, AEM bruteforce intake, 5 inch MBRP turbo back to 6 inch black tip, 20% tint, black toolbox, and a few other goodies
wiblueboy is offline
post #2 of 9 Old 01-17-2014, 06:30 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Looks like the badge says F250. If it's stock you could swap in some F350 blocks for a small bump. Otherwise aftermarket 4" or 5" blocks would be best. Be ready to feel a tad more driveline vibration if you go too high. Make sure you get the right rear lift blocks.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 9 Old 01-17-2014, 10:02 AM
Quoted: 2 Post(s)
What are the right blocks
89ezgo is offline
post #4 of 9 Old 01-17-2014, 10:05 AM
N.S.D.Q.
Quoted: 97 Post(s)
Some blocks have a taper others are flat. I think the CCLB trucks use the flat blocks. The shorter trucks have the tapered blocks.
post #5 of 9 Old 01-17-2014, 10:39 AM
Quoted: 2 Post(s)
Where a good place order a set of 2-1.5 flat blocks i have a 6inch lift in the truck now with a three inch block stacked on a factory block i want to go down on the rear can i just pull the 3inch block out slide in a 2inch or 1.5 and go on my way
89ezgo is offline
post #6 of 9 Old 01-17-2014, 12:10 PM
I responded to your thread, 89ezgo.
Check out Newton's Lift. They seem to be reputable around here. I am about to order a 4" rear block from them to accommodate my 2.5" front end spacer. I am a tad nose high right now. I want some rake back for towing...
TxOutlaw is offline
post #7 of 9 Old 01-19-2014, 02:17 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
If you want to keep you trucks look (leveled) when not towing, then add a set of Firestone Ride Rite airbags to the back. I have these and all you do is add air to them when you are going to tow your trailer to stop the sag!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #8 of 9 Old 01-28-2014, 05:25 PM Thread Starter
If I do the f250 blocks, which are actually 2" taller than the f250, will I need to do anything to my driveshaft? Thought I read somewhere that I would
post #9 of 9 Old 01-28-2014, 05:49 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
100% agree. Ive got a set on my 2012 f250 work truck and I beat the snot out of that poor truck. But so far I have yet to have a bag give out. Without them I sag bad even with over loads.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
