Double Checking 2.5" Coil Spacer... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-16-2014, 10:49 AM Thread Starter
I am about to order shocks and want to be sure I truly have a 2.5" coil spacer before ordering correct length shocks...
Previous owner had billet alum bottom installed coil spacer installed. I am getting 2.25" (roughly) actual size. I have read that some spacers will be shorter than actual raise height.
Am I safe to order shocks for 2.5" ride height? I am a tad nose high...
Still debating on Bil 5100's or Rancho 9000 shocks... I am leaning towards bils up front, Rancho in rear for stiffening up when towing/hauling.
TxOutlaw is offline
post #2 of 5 Old 01-16-2014, 04:49 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 104 Post(s)
Feedback Score: 3 reviews
If you use the shocks that Bilstein uses in their leveling kit you would be fine. 2.5" shocks on 2.25" lift is fine.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 5 Old 01-16-2014, 04:52 PM Thread Starter
Good point. I saw that now their stock ride height shock is for 0-2.5, used to be 0-2"...
Rancho next step from stock is 2.5". I guess that is why I am checking. I don't want to get shocks to wrong length. I can measure the distance I have now between the 2 shock bolts, shoulda done that when I went out there earlier...
When I put a 4" block in the rear, I doubt that front shock length would change, right?
TxOutlaw is offline
post #4 of 5 Old 01-16-2014, 05:02 PM
N.S.D.Q.
Quoted: 104 Post(s)
If you were in the Baja it might be an issue. I see no problem with 1-2" longer shock on most trucks. If you wanted to run a 4" lift shock on an 8" lift you would have issues. Run an 8" lift shock on a 4" lift you will have issues. The 4" block will not affect the front enough to worry about.
I try to compare part numbers between kits to see what they use. I think the Bilsteins I just bought for my 6" kit were within the 1-2" of what I took off. I was running shocks for a 4.5" kit. I never had problems.
post #5 of 5 Old 01-16-2014, 05:51 PM Thread Starter
Gotcha! Thanks!
TxOutlaw is offline
