Lifted truck doesn't feel right - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 01-15-2014, 06:13 PM Thread Starter
I recently bought a 05 f250 harley which drove pretty nice. I installed a 6 inch rough country lift kit, not the one with radius arms. I also added 37 inch tires and had it aligned. At first it was real sloppy and found that the pitman arm nut had loosened up so bought a new nut and that seems to have fixed that but the truck just seems to wander a bit and pretty bouncey also. I do have the dual steering stabilizer also. I've checked the front end a couple times and don't see any problems, any ideas where else to look?
tking7 is offline
post #2 of 13 Old 01-15-2014, 06:36 PM
huck2080's Avatar
track bar ?
huck2080 is offline
post #3 of 13 Old 01-15-2014, 06:38 PM Thread Starter
Track bar is tight. Also notice that the springs in the front bow forward a bit, is this common. Kinda scary since there really isnt anything keeping the springs in there.
tking7 is offline
post #4 of 13 Old 01-15-2014, 07:45 PM
huck2080's Avatar
i could be wrong but i dont think they are suppose to bow forward ... did it come with drops for the raduis arm ? is there a leveling kit stacked on top of it ?
huck2080 is offline
post #5 of 13 Old 01-16-2014, 02:57 AM Thread Starter
Yes it has drops for the arms. no blocks on top though
tking7 is offline
post #6 of 13 Old 01-16-2014, 03:11 AM
Lift
[I] have a 6inch rough country and this is how my springs look, ialso have steering stabalizers,
ID:	227274   Click image for larger version
jpboats is offline
post #7 of 13 Old 01-16-2014, 08:29 AM
Skyd Ram's Avatar
Quoted: 140 Post(s)
The coil bowing is pretty normal especially for those taller coils.
You say that you hade it aligned but what were the final specs after the alignment?
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #8 of 13 Old 01-16-2014, 08:35 AM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
37 by what on what rim width?
My 15.50s walked like crap.
GD
Heavy_GD is offline
post #9 of 13 Old 01-16-2014, 12:07 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I can tell you exactly what the problem is. The Rough Country has flimsy drop down brackets for the radius arms. I had the same lift when I bought my truck and mine would wander and hunt around the lanes depending on how good the road was.
I started at the radius arms on my truck, went with Fabtech radius arms and removed the drop down brackets. The difference was immediate now the truck goes where I point it.
Plus drop down brackets look bad on a 6" lift, the oem radius arms stick out like a sore thumb. 4" you can get away with but not 6".
Also make sure that everything is tight including U-Bolts on rear axle.
Good luck on it, I know from my own experience with my truck.
huck2080 likes this.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #10 of 13 Old 01-16-2014, 02:07 PM
F250SixOH's Avatar
Is it a radius arm drop or a 4 link?
F250SixOH is offline
