How long do factory coils last on 05 PSD? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 23 Old 01-10-2014, 04:21 PM Thread Starter
I am about to replace all 4 shocks with bilstein or rancho 9000's but I have been considering replacing the factory coils and 2.5" spacer at some point. My truck has 156K on it and I intend to keep it for a long time. I will be swapping the rear block out for an F350 block in the future as well..
Main Q, how long should I run the factory coil?
TxOutlaw is offline
post #2 of 23 Old 01-11-2014, 09:51 AM
Quoted: 51 Post(s)
Most 4x4 Super Dutys are too softly sprung as it is, plus the springs are made in Mexico and soften over time. Suggest looking at what coils you currently have, and increase at least 2 sizes. I went from 5,200 lb to 6,000 lb, and then to 7,000 lb coils. I love the 7,000s. They were very stiff at first but quickly softened-up. Look at the spring code on your door tag, or on the coil itself. The last two letters of the code indicate the strength of the coil.
AA=7000, AB=6500, AC=6000, AD=5600, AE=5400, AF=5200
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 23 Old 01-11-2014, 10:16 AM
Why not order some 2.5" progressive rate springs from carli?
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #4 of 23 Old 01-11-2014, 11:53 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
My spring code is AF. What would going to a AD or AC code do to the front height? I already run a 1.5" leveling kit and don't want to go any higher in the front
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 23 Old 01-11-2014, 06:23 PM
Quoted: 51 Post(s)
Matt-
My truck originally came with AF coils. It would bottom out turning into my suburban driveway. You could also tell by the bump stops it was bottoming-out fairly often.
If you went with ACs (6k), which is what the snow plow prep package comes with, you would be about .5" lower in the front than level (with your spring spacer removed). I wouldn't bother going to ADs, as you won't even know the difference from the AFs.
Currently I'm running AAs with a 1" lower Icon spacer. This made my truck nose high by about 1". I've since added a 1.5" soft ride add a leaf in the rear which really helps with heavy loads and our Lance camper.
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #6 of 23 Old 01-12-2014, 08:04 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
I would ultimately like to go with a 3" block in the rear and still have my front about a 1/2" lower. I do not want to be totally level and I also don't want to step all the way up to 350 rear blocks. All I tow is a little bass boat with 12x4.80 tires and my drop on my receiver is already 3 1/4"
-Matt
2015 F-250 XLT 6.7L
post #7 of 23 Old 01-12-2014, 12:01 PM Thread Starter
Good input. I don't feel they are too soft at this time so maybe I am OK for now, unless the rough ride is from them being too soft... I will go forward with new shocks and address the 2.5" progressive coils at a later time and do away with the spacer then.
Thanks!
TxOutlaw is offline
post #8 of 23 Old 01-13-2014, 10:52 AM
x96535's Avatar
Post up once you get the new shocks installed and let us know how it effects your current ride. My truck seems to ride pretty stiff as well, so I'm considering switching out all four shocks. I'm also leveled and on 35's.
x96535 is offline
post #9 of 23 Old 01-13-2014, 11:08 AM Thread Starter
Will do. Going with Rancho 9000xl adjustable for 2.5" leveled from end. Stock height in back. Hope they will work well when I raise the back with F350 blocks.
TxOutlaw is offline
post #10 of 23 Old 01-13-2014, 01:09 PM
x96535's Avatar
I got the item number RS999043 for the RS9000xl's on the front with the 2.5" lift, but the only option for the rear on their website was a lift of 5" or greater.
I have the F350 blocks, so I'd assume the stock ride height shocks would be ok since the 5" option would seem a little extreme. What was the model number for the rears and where did you buy them? Cheapest I'm seeing is Amazon for $95.70 a piece.
x96535 is offline
