PLEASSEEEE.... HELP me identify & fix my air suspension kit! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-09-2014, 08:23 PM Thread Starter
RJ's325ITS's Avatar
Question PLEASSEEEE.... HELP me identify & fix my air suspension kit!
I just bought this fixer upper 2000 F350 2WD Dually, and I’m running out of money fixing everything so please keep that in mind!
So, while I was repairing the front wheel bearings, the wobbly driveshaft and replacing all the busted shocks I realized the truck came with air bags in the rear axle, I started to look all around when I see a few things wrong:
1. The front right u-bolt is broken
2. The rear right u-bolt is bent on the top
3. The bottom main plate for the rear air bag, right side looks like it bottomed down at some point and hitted the main axle U-bolt see the pics for details. (do you guys think it will be okay to used it? Or should I replace it?)
I bought this truck to tow in the future a gooseneck dual car trailer, so I think these air bags will come handy in the future!
I’ve looked everywhere for the square u-bolts and nothing, all I found was either too long or too narrow…
The bolts are:
0.336in (diameter)
3.16in (width)
4.88in (length)
These are the closest I found and they looked kind of expensive to me, what you guys think?
Square Bend U-Bolts - 5/8" x 3 1/16" x 5 3/8" - 361-448 | $19.95
I know nothing about air suspensions so please look at the pics and if you are familiar with this kit please poor your knowledge here…. The airbags don’t look too bad to me, and they hold air. I manually pumped about 40psi in both sides and held it up just find! Oh the other 2 things that don’t work are the rear pressure gauge… is dead, the needle does not move, and there is a switch that “I think turns on the small compressor under the cab” that does nothing when press ON……
Oh, well learning about air suspension the hard way!
broken bolt, this pic was taken from the front of the rear right side wheels
this is the how the rear part of it looks, notice the bent bolt, this pic was taken from behind the rear right side wheels
LEFT SIDE: plate is not touching the main bolt for the axle....
RIGHT SIDE: Notice where the bolt hit the place and made a mark, the plate is touching at all times now!
AIR BAG:
Is this a compressor????
Thank you!
2000 F350 Dually, Bullydog GT, Straight exhaust, Riff Raff filter, front grill cut out.
RJ's325ITS is offline
post #2 of 6 Old 01-10-2014, 01:32 AM
Quoted: 760 Post(s)
Sdleafspring.com
Suspension king.com
Corey@CNCFAB is offline
post #3 of 6 Old 01-10-2014, 05:11 AM
schlutzer's Avatar
Quoted: 18 Post(s)
TBH any spring shop ( most heavy diesel shops ) can bend you a square ubolt for a couple bucks.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 6 Old 01-10-2014, 05:42 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Holy shoot what kinda loads was the PO hauling with that?? Obviously not loaded real good or going down some bumpy arse roads
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 6 Old 01-10-2014, 11:55 AM Thread Starter
RJ's325ITS's Avatar
thank you guys, I'm pretty sure is an Air Lift system; I just sent and email with the pics since their parts have a lifetime warranty, I'll see how that goes before i move in any direction.
I pumped about 10psi yesterday and I will see if the system leaks at all, the I will get a replacement gauge so I can tackle the air compressor.... Perhaps is minor stuff and I can salvage this kit for the future.
post #6 of 6 Old 01-10-2014, 12:36 PM
jesilvas's Avatar
Quoted: 2 Post(s)
It looks like AirLift to me too.
4R100, 2wd
330,000 + miles
jesilvas is offline
