Question for you guys that have had auto hub problems - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 01-05-2014, 07:45 AM Thread Starter
Did you get any indication there was a problem? My 4x4 light comes on fine but I suspect the hubs aren't locking in. I would have thought there would be some indication there was a problem if they didn't lock.
Did you go manual hubs or replace the oem auto hubs? Looks like the autos are about 200 each.
PeeVee is offline
post #2 of 16 Old 01-05-2014, 07:49 AM
ZMANN's Avatar
Quoted: 1464 Post(s)
the system can not verify hub actuation it can only verify the transfer case shift motor has done it's job and set the dash indicators accordingly
We Miss you Ronnie
ZMANN is online now
post #3 of 16 Old 01-05-2014, 07:51 AM
ZMANN's Avatar
easy check
select 4high drive a bit forward and stop truck put in park or shut off
reach into the knuckle and grasp the u joint for each axle shaft if you can turn one by hand the hub did not lock
We Miss you Ronnie
ZMANN is online now
post #4 of 16 Old 01-05-2014, 07:52 AM
ZMANN's Avatar
also the choices for manual hubs are dependent on year and you did not state that ??
but 05 up has no viable choices
We Miss you Ronnie
ZMANN is online now
post #5 of 16 Old 01-05-2014, 07:52 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 896 Post(s)
Feedback Score: 6 reviews
Have you checked to see if all the tubes to the hubs are connected? A buddy of mine had an issues with his hubs not locking in, but found that one of the tubes wasn't hooked up.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 16 Old 01-05-2014, 07:54 AM
ZMANN's Avatar
your buddy had his tubes tied ?
supreme oppressor likes this.
We Miss you Ronnie
ZMANN is online now
post #7 of 16 Old 01-05-2014, 07:56 AM
RIP Cam!
Quoted: 896 Post(s)
That's exactly what I said.
post #8 of 16 Old 01-05-2014, 08:09 AM Thread Starter
easy check
Good idea thanks
PeeVee is offline
post #9 of 16 Old 01-05-2014, 08:10 AM Thread Starter
03........
PeeVee is offline
post #10 of 16 Old 01-05-2014, 08:12 AM
ZMANN's Avatar
Originally Posted by PeeVee View Post
03........
then u should be able to find a full manual aftermarket version from a few sources
but just remember the OEM is a Warn unit and has a manual lever
so if it still turns and locks u can save your $$ and just block off the ESOF vacuum at the valve and knuckles to go manual only
We Miss you Ronnie
ZMANN is online now
