Rear Block Swap - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-03-2014, 03:32 PM Thread Starter
xp1ik05's Avatar
Rear Block Swap
Yes I've searched, trying to find out what I've got, finally was able to score some f350 blocks from the junk yard from an 08, my first question is are there any major differences between the rear axle of the 08 350 and 04 250 (I.e. axle diameter block width etc.) that I need to be aware of prior to tearing everything apart? Have the u-bolts from it and they just seem bigger......not trying to reuse them but more of a reference. Thanks ahead of time and sorry for another thread regarding a common general question.
04 ECLB 4x4
6.0/4 IN. MBRP 6 IN. Tip/Blue Spring/XDP Coolant Filter/SCT Tuned by Stroked Diesel/IDP FICM Tune/S&B Intake/Stroked Diesel EGR Delete/Boost-EGT-Trans Autometer/SG2/Leveled/Cal-Tracs/20x12 MM962's/305-55-20 Terra Grapplers/
xp1ik05 is offline
post #2 of 12 Old 01-03-2014, 08:21 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 466 Post(s)
Garage
I don't know the differences except that the 350 is 2" taller.
Nothing wrong reusing ubolts as long as the threads sure good and rust isn't a issue.
Make sure spring pins are same for axle. If it fits use it
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 12 Old 01-04-2014, 03:52 AM Thread Starter
xp1ik05's Avatar
Ya I know that much. Just trying to find out any major differences between 04-08 rear axles
04 ECLB 4x4
xp1ik05 is offline
post #4 of 12 Old 01-04-2014, 04:08 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 116 Post(s)
Feedback Score: 3 reviews
I think the blocks are different between cab/bed configurations. Something about the block being tapered or flat. So a CCLB could be flat while a EXSB would be tapered something like that. As long as the truck you pulled them off of is the same cab/bed as yours you should be fine. The different blocks are due to the driveshaft alignment and vibrations.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #5 of 12 Old 01-04-2014, 04:11 AM Thread Starter
xp1ik05's Avatar
Yes i know all of this, they are flat blocks, I'm really not trying to find out anything regarding the blocks I'm trying to find out if the axle has changed at all from 2004 to 2008. More or less a curiosity thing.
04 ECLB 4x4
xp1ik05 is offline
post #6 of 12 Old 01-04-2014, 04:26 AM
N.S.D.Q.
Quoted: 116 Post(s)
Nope, No change that I know of between the years.
post #7 of 12 Old 01-04-2014, 04:52 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Exterior of the axle hasnt changed. The only changes are the axleshafts and number of splines
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 12 Old 01-04-2014, 04:55 AM Thread Starter
xp1ik05's Avatar
thank you, so when a company asks for exterior diameter of the axle its still the same regardless of year for the most part, 99+
04 ECLB 4x4
xp1ik05 is offline
post #9 of 12 Old 01-04-2014, 05:01 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
3.625 is your axle diameter
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 12 Old 01-04-2014, 04:38 PM Thread Starter
xp1ik05's Avatar
ok last question, is the 08 axle the same diameter? i was unable to track down some new u-bolts today like i had planned and want to get these blocks in tomorrow, they fit over the axle but they just seem alittle bigger if that makes any sense
04 ECLB 4x4
xp1ik05 is offline
