Carli 2.5 Leveling Kit - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 29 Old 12-28-2013, 02:53 PM Thread Starter
Davenport's Avatar
I have a 2014 F-350 Platinum SRW and I'm thinking about using this leveling kit after reading a lot of good things about it on this forum.
I like my factory wheels (The factory wheels are 20x8) I'm considering running 35X12.50R20-MT Toyo Open Country tires will this be a problem?
Also, if you have the Carli 2.5 leveling kit installed and are running 35's will you please post pictures of your truck. Thanks in advance!
Davenport is offline
post #2 of 29 Old 12-29-2013, 02:21 PM
Skyd Ram's Avatar
Quoted: 140 Post(s)
That should work out just fine. The width on those tires is over 13" so you may experience some mild rubbing at full steering lock because of the factory wheel backspacing.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #3 of 29 Old 12-29-2013, 02:44 PM Thread Starter
Davenport's Avatar
Thanks for the info. Also, if anyone has the Carli 2.5 leveling kit installed and are running 35's I would appreciate it if you would post pictures of your truck. Thanks.
post #4 of 29 Old 01-08-2014, 12:46 PM
Come on guys no one has/needs this/these questions answered?? Isn't this what forums are for? I'm installing the new carli 2.0 commuter as soon as it arrives to me in Austin tx which should be by fri ... I have the exact same questions for my application and possible aftermarket rims. Thx in advance fir anyone's input.
tx 250 is offline
post #5 of 29 Old 01-08-2014, 03:57 PM
OCVeloMan's Avatar
Quoted: 173 Post(s)
Garage
Carli 2.5" with 17" wheels and 35" Toyo ATII
George andwered the fitment question above. You can run a 35" Toyo Mud on factory rims but your ideal situation is no more than 9" wide on the wheels with 5"-5.75" of backspacing on the 2.5" lifts. This will clear the radius arm and the lesser of the backspacing (around 5") will only require minor trimming.
OCVeloMan is offline
The Following User Says Thank You to OCVeloMan For This Useful Post:
Davenport (01-08-2014)
post #6 of 29 Old 01-08-2014, 04:44 PM
O--your always "the man" when it comes to feedback, customer or not... This is what feeds this site and keeps me interested in purchasing/improving my TOY!! Will post pics upon installs. Dan at Carli has requested pics as well... My new wheels will be first out SIC...Stay tuned!! Thx again.
tx 250 is offline
post #7 of 29 Old 01-08-2014, 05:16 PM
OCVeloMan's Avatar
Quoted: 173 Post(s)
Garage
I am Dan @ Carli! Excited to see the wheels!
76hauler likes this.
post #8 of 29 Old 01-08-2014, 07:39 PM
No problem with those 17" wheels clearing the brakes? I have a 08 F350 and looking to go down from the stock 20" to a smaller wheel for a bit better ride. I would assume a 35"/17"s would ride better than 35"/20"
BigPSD is offline
post #9 of 29 Old 01-09-2014, 05:47 AM
Skyd Ram's Avatar
Quoted: 140 Post(s)
Nope,
You can get these truck from the factory with 17's. I ran 37's on 17x9's on my 08 with a 4" system.
And yes,
The bigger the tire and the smaller the wheel the better the ride. This is due to a combination of sidewall height, sidewall stiffness, and air volume in the tire.
Also,
The bigger the tire the easier that it is going to roll over bumps and dips in the road. Bigger tires won't drop down as far into potholes and expansion gaps.
888-886-2480
Skyd Ram is offline
post #10 of 29 Old 01-10-2014, 07:20 AM
Carli 2.5 w/ 37x12.5x20 Dick Cepeks
AnimalMother is offline
The Following User Says Thank You to AnimalMother For This Useful Post:
robleticia (02-02-2014)
