01 f250 front upper and lower shock mounts - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By jetjock15
post #1 of 3 Old 12-26-2013, 03:45 PM Thread Starter
I have an 01 f250 4x4 7.3l and currently I have a dual shock setup (hoop style) on the front of my truck. I want to put it back to the stock one shock set up but I cannot find the mounts anywhere except from ford and I would not like pay the $250 ford wants for just the upper mount. Does anyone know where I can find the upper and lower shock mount for not an arm and a leg? Thank for the help1
USMC7.3EOD is offline
post #2 of 3 Old 12-26-2013, 04:11 PM
alaskan155's Avatar
Quoted: 60 Post(s)
junkyard would be my place to stop, 99-04 will work and are the same for f-250-550s and excursions. if you still can find it, you should be able to modify a 80-96 f350 mount pretty easy to work, they are around $30 from ford.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
The Following User Says Thank You to alaskan155 For This Useful Post:
Heavy_GD (12-26-2013)
post #3 of 3 Old 12-26-2013, 05:44 PM
jetjock15's Avatar
Quoted: 113 Post(s)
You can call truck toys, 888-PROTOYZ , they have a pile of parts off trucks they awayls willing to help a brother out.
huck2080 likes this.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
