Leaf Spring Question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-22-2013, 05:57 PM Thread Starter
jeffro22's Avatar
Quoted: 5 Post(s)
Was looking to do a mod to my rear leaf springs. I need a longer bolt that holds them all together though. since I am adding a leaf where can I get the bolt that goes in the middle of the spring that holds everything together? It has a knob on one end that fits into the block
jeffro22 is offline
post #2 of 13 Old 12-22-2013, 09:55 PM
Usually the add a leaf kit will come with a longer center pin to put it all together.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #3 of 13 Old 12-23-2013, 04:47 AM Thread Starter
jeffro22's Avatar
Quoted: 5 Post(s)
unfortunately it is not a kit. I am trying to do a B spring mod, but the b springs I got had already been modded and the center pin cut. Now I need to add in a leaf to get my truck sitting correctly.
It looks like i can buy the longer pins. Just needs to figure out the correct size and style
does anyone know if something like this is the right size?
http://www.ebay.com/itm/Leaf-Spring-...1ba94d&vxp=mtr
jeffro22 is offline
post #4 of 13 Old 12-23-2013, 03:02 PM
What is b spring mod?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #5 of 13 Old 12-23-2013, 03:40 PM
c dog's Avatar
If your springs all ready have the "B" mod then I would look into airbags. You can buy a kit for $300-$400. Air bags would ride better and be more practical than a add a leaf.
Sent from AutoGuide.com App
c dog is offline
post #6 of 13 Old 12-23-2013, 05:40 PM
huck2080's Avatar
if you have a driveline shop anywhere around you might find it there
huck2080 is offline
post #7 of 13 Old 12-26-2013, 06:25 PM
jetjock15's Avatar
Quoted: 110 Post(s)
Any leaf spring or heavy duty truck shop can get you the bolts or you can order online.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 13 Old 12-27-2013, 08:02 AM
I bought mine from Fastenal.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 13 Old 12-27-2013, 10:25 AM Thread Starter
jeffro22's Avatar
Quoted: 5 Post(s)
Thanks for the response. I found some online, just going to confirm the size today and get them ordered
just involves swapping some leaf springs and spacers around from the stock excursion springs into the B code springs.
I bought used springs and someone took the spacer out already and cut the pins/bolts
jeffro22 is offline
post #10 of 13 Old 12-27-2013, 01:44 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
I still don't understand the B mod for the springs.
Excursion leafs mixed into the spring pack?
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
