Need death wobble help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-22-2013, 05:04 PM Thread Starter
greggo2208's Avatar
2010 F-350, CC 4x4 LWB.. Same story as everyone else.. anything 40mph or up and the slightest bump or change in the road sends my truck rattling and shaking the teeth out of my head. The difference is that I don't have a lift as many of the others that have posted about this problem do. I have 35in 12.50x20 tires on stock rims, but I had the wobble even before replacing the stock tires. Everything I see points to the track bar. Does that sound reasonable? Replacing the track bar would repair the problems? If so what is a good aftermarket product to use?
2010 F350 King Ranch, AFE C.A.I., Flo Pro 5" turbo back, H & S XRT Pro -Hot Damn 300m, RBP 6" tip, Ranch hand brush guard..Always low on fuel...
greggo2208 is offline
post #2 of 4 Old 12-22-2013, 09:56 PM
Check the balljoint at the axle end of the track bar, these wear out allowing play which can lead to the wobble.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #3 of 4 Old 12-23-2013, 06:20 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Check:
Tire pressure.
Front end alignment.
Steering stabilizer; Pull the bolt and inspect amount of play in track bar sleeve.
Steering box play.
Jack up front end and rock steering wheel back and forth and look for play in all of steering parts.
Anything loose will do it.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 4 Old 02-12-2014, 01:11 PM
stroken828's Avatar
Check out the "superduty hop" thread. just search that under general suspension and steering. its a long thread but may lead to some answers for you. helped me with my problem.
stroken828 is offline
