Improving 8" leaf springs - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 23 Old 12-18-2013, 10:19 AM Thread Starter
My 04 ccsb has 8" superlift front springs with procomp shocks, and it's ridiculously stiff.
Will i see a worth while improvement in purchasing better name brand leafs? I've found some fabtech springs for $550, and havent seen any icon springs for under $850. Would i be wasting my money?
DTHA is offline
post #2 of 23 Old 12-18-2013, 11:05 AM
A 4 inch hanger and a 4 inch lift spring would be my advice if improving ride quality is what you're after.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 23 Old 12-18-2013, 12:31 PM
layson's Avatar
Quoted: 82 Post(s)
I had 8" icon springs with 4" hangers and it road fantastic. I also had the icon signature series shocks. I would think you would feel an improvement going to another 8" spring. But you could also go with the 4" spring with the 4" hangers as well...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #4 of 23 Old 12-18-2013, 02:47 PM Thread Starter
How are the fabtech springs? More interested in those seeing how they are $300 cheaper
DTHA is offline
post #5 of 23 Old 12-18-2013, 03:30 PM
huck2080's Avatar
fabtech is ok but the icon are the best riding leaf spring on the market for the superduty .. the hangar and spring will ride better as you will have less spring arch
huck2080 is offline
post #6 of 23 Old 12-18-2013, 03:32 PM
huck2080's Avatar
just re read your post supelift are real good to i would invest my money in better shocks you would be shocked at how much better a good shock will ride
huck2080 is offline
post #7 of 23 Old 12-18-2013, 04:17 PM Thread Starter
I'm away from my truck but if i remember right it has 11-13 leaf packs. The rough ride is mostly from violent bumps, not so much bouncyness
DTHA is offline
post #8 of 23 Old 12-21-2013, 05:33 PM Thread Starter
Any other opinions?
DTHA is offline
post #9 of 23 Old 12-23-2013, 06:42 AM
Quoted: 3 Post(s)
The Icon 8" springs ride great with properly valved shocks. This would be a huge improvement over your superlift springs.
For the best ride, get 4" Icon springs and a 4" hanger kit with new shocks
This has already been said in the posts above me. I've personally ran both setups and they're far superior to Superlift
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #10 of 23 Old 12-23-2013, 06:43 AM
Quoted: 3 Post(s)
Also, check your tire pressure. You do not need to be running your tires at full psi except for when loaded. I run 38-40" mud grapplers at 45 psi in the front and 40 psi in the rear
01 Ex 7.3l Limited
06 headlights
