What's causing vibration? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-15-2013, 06:58 PM Thread Starter
My 2014 f250 crew cab, single wheel was about an inch low in rear so I installed a 5 inch procomp level kit which now gives me a slight rake which I like and which should level out when I hitch a trailer. However, now when I start slowly from a start I get a rumble strip type of vibration at right about 10 mph. Any ideas or suggestions on what may be causing it or how to remedy? Everything is stock other than the rear level kit. Thank you
Yessir is offline
post #2 of 4 Old 12-15-2013, 11:38 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Make sure u bolts are tight and did you raise the carrier brg. A 5" lift should see 1"-1-1/2 spacers for it to smooth out driveline angle.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 4 Old 12-16-2013, 04:58 PM
5fifty's Avatar
Sounds like drive line vibrations like mentioned above. It can be axle wrap as well. The rear spring s twist up on acceleration from a stop causing the rear drive shaft to be out of plane with the pinion. Blocks at times can cause this.
5fifty is offline
post #4 of 4 Old 12-16-2013, 06:13 PM Thread Starter
fixed
Thanks all. I took it in and they put the smallest shim from the procomp kit and that seemed to solve the problem as it would only happen occassionally. I appreciate the advice.
Yessir is offline
