airbags with a lift - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-13-2013, 01:59 PM Thread Starter
airbags with a lift
Has anyone put Ride Rite airbags on a truck that has a lift on it? Were there any issues with it?
rc.chris is offline
post #2 of 5 Old 12-13-2013, 02:19 PM
Duncan's KR's Avatar
it really depends on how much lift you have and how you use the truck. With a large lift you will have to look at air springs with a lot of travel either a Triple convoluted air spring or a sleeve style. You can also look at the daystar air spring cup that allows the for the air spring not to have to be bolted down on the bottom. There are lots of companies who do air springs, I most likely will end up putting my own together been looking at Air Suspension Pros | Find Quality Suspension Lowering & Lift Kits for some of the stuff, I used to use their stuff back in the day when I was building my street truck.
Regards,
Duncan
2005 F250 King Ranch (Modification list made)
2006 Jeep LJ "Just my little heap that I like to creep"
Duncan's KR is offline
post #3 of 5 Old 12-13-2013, 02:28 PM Thread Starter
6" lift and I want it to help take the some squat out of truck when pulling my fifth wheel.
rc.chris is offline
post #4 of 5 Old 12-14-2013, 04:13 PM
I've installed special brackets from ride rite on an 06 f350 with 6" lift to run their normal bag set up.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #5 of 5 Old 12-14-2013, 04:29 PM
fordtrix's Avatar
6" is a lot. You would need to fab brackets or I believe they sell spacers. They wont work without modification
fordtrix is offline
