Lift kit difference between 06-08 trucks? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-03-2013, 02:27 PM Thread Starter
I'm looking at buying a used ProComp 6" full lift kit that a guy had on a 2006 F250. My truck is a 2008 F350. I'm wondering what, if any differences there are, or will the kit bolt right on? I don't want to spend the money if I can't use everything I buy.
thedudebrah is offline
post #2 of 2 Old 12-03-2013, 05:26 PM
SS4Matt's Avatar
I know that the '08 and above trucks have a longer rear leaf spring. So if the pro-comp kit has replacement rear leafs, they would not work.
Also, I am pretty sure (not 100% certain) the '08+ trucks have a different u-bolt setup in the rear. ('08+ the u-bolts go over the top of the leaf spring and are bolted to a plate under the axle, where as the pre '08 trucks have a u-bolt that goes under the axle and bolts to a plate on top of the leaf spring)
I am not certain if there are any differences with the front as far as a lift goes though? (I think the sway bar & mount may be different on the '08-'10 trucks than the '05-'07)
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
