Drive Shaft - Ford Powerstroke Diesel Forum
post #1 of 61 Old 12-02-2013, 07:03 AM Thread Starter
Drive Shaft
I am going to a driveline store today and want to make sure I have all of my duck in a row. I have an 07 CCSB 4wd and going to have them make a 1 piece drive shaft. Talking to them over the phone they want to make it 4" because of the length. The stock 2 piece drive shaft looks like there is a flange at both ends of the drive shaft with no slip yoke at the transfer case. Is this even possible?
2007 Lariat Crew Fx4, 20x9 D.E.J Wheels, 37x13.50, Toyo MTs, 6" Lift, Billet grill, '08 Mirrors, 4" TB Diamond Eye, AFE CAI, PMM coolant filter, Blue spring mod, Scangauge II, Pod mount FP gauge, SCT X3 - Looney tune
1fast68 is offline
post #2 of 61 Old 12-02-2013, 07:32 AM
ZMANN's Avatar
Quoted: 1894 Post(s)
the slip is near the carrier bearing
you will need the same setup minus the carrier
they will probably put the slip near the upper flange
take your truck in for them to look at IMHO it is your safest bet
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #3 of 61 Old 12-02-2013, 10:36 AM Thread Starter
Thanks Zmann. Figured it out but couldn't update from my phone. Took it in for them to look at and they want me to fix my pinion angle first. They measured all my angles and told me what they should be set at. They were super nice and trying to save me some money. Didn't even charge me for checking all the angles and said if I fix the angles I might not even need a new shaft. ....We'll see, I sure hope not.
1fast68 is offline
post #4 of 61 Old 12-02-2013, 05:12 PM Thread Starter
Ok, adjusted my pinion angle and still vibrates, changed shims on carrier bearing, still vibrates, done several combinations of the 2 and it still vibrates. No matter what I change I get a vibration at around 50 mph, nothing I have changed makes it worse or better. Shouldn't changing shims on the axle or bearing change the speed or severity of the vibration?
1fast68 is offline
post #5 of 61 Old 12-03-2013, 09:59 AM
U-joints? How about rotating some tires or check to see if they are all balanced up.
Bakken64 is offline
post #6 of 61 Old 12-03-2013, 06:31 PM Thread Starter
Thanks, rotated tires, still there. Will be ordering a one piece driveshaft tomorrow.
1fast68 is offline
post #7 of 61 Old 12-04-2013, 07:38 AM
Are you stacking shims or clocking the carrier bearing? Stacking shims will destroy a cb. You are trying to put an angle where it was never meant to be. Clocking the cb keeps it straight and removes vibration. I think OUO has a piece to do this.
Look at the carrier bearings on a large moving truck, they are clock (perpendicular to driveshaft centerline.
A 4" shaft is needed because anything smaller will act like a jump rope at that length and self destruct.
In the end, clocking the cb will be cheaper, safer, and just as effective as a 4" one piece.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 61 Old 12-04-2013, 08:01 AM
atvrider93's Avatar
Quoted: 8 Post(s)
Have you tried replacing the carrier bearing
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #9 of 61 Old 12-04-2013, 08:31 AM
ZMANN's Avatar
not sure I would use the term "clocking" if your referring to
matching the carrier bearing angle to match the drive shaft? you can clock the front transfer case to help the front shaft but the rear CB is more of matching angles
He's ordered the 1 peice so He will know soon enough if He has a problem somewhere else
I just used a carrier bearing drop bracket that let you align everything and had no issue
I will say that was nice of the shop to spend the time on your angles
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #10 of 61 Old 12-04-2013, 11:00 AM
That would be the part I meant. Rotate, clock, however you want to say that you're maintaining a straight line through the carrier bearing.
Karl and his 2003 Super Doody
Karls03 is offline
