Questions on a better ride 2006 F250 4x4 (Suspension Upgrades) - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-29-2013, 09:52 AM Thread Starter
RuHunting's Avatar
I'm thinking about installing a Leveling kit on my truck maybe even an airbag suspension on the rear to level things out when I tow. I want to hook up the boat first before I make this decision. I also want to keep the factory (20") wheels and tires. I do not want to get to aggressive with lift kits and larger tires. I do a lot of towing and the occasional 4x4 drive down the beach.
I'm also thinking on new shocks with this install and a steering stabilizer kit.
Where should I go to find leveling kits, airbag systems and steering stabilizer kits (brands)?
Help with links from this forum (info and builds)?
Will I need to look into a special type shock with a leveling kit?
RuHunting is offline
post #2 of 14 Old 11-29-2013, 08:24 PM Thread Starter
RuHunting's Avatar
I've done a little digging and found these for the front of the truck. If I'm reading this correctly It will lift the front end 2.25".
Bilstein, Innovation and High Quality Since 1873
BTS System - Toyota Tundra & Ford F-250/F-350
What about this one for the steering?
5100 Series - Steering Damper
Opinions?
post #3 of 14 Old 11-29-2013, 08:33 PM
ZMANN's Avatar
Quoted: 1564 Post(s)
your link shows a tundra coil over I think the ford is just replacement coils and shocks
if I were u I would not expect a better by much ride from any lift just the shocks and if u really want a minimal all in one kit look at ready lift lots of happy users post here
or build your own with a front coil spacer /new shocks all around ( while not necessary for a minimal lift the OEMs suck ) and dial in the rear using a block to match your desired height
fyi Bilsteins are a harsher ride than some other brands I preferred the adjustable Rancho's myself
We Miss you Ronnie
ZMANN is offline
post #4 of 14 Old 11-29-2013, 09:09 PM Thread Starter
RuHunting's Avatar
post #5 of 14 Old 11-29-2013, 11:16 PM
JesseKK's Avatar
Quoted: 48 Post(s)
Garage
Teh dual steering stabilizer from rough country is awesome. It looks good, works good and for $150 ready to bolt on, ur not gonna beat it.
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #6 of 14 Old 11-30-2013, 05:01 AM Thread Starter
RuHunting's Avatar
I couldn't find a leveling kit from Rancho. Looks like everything on their site for ford leveling/adjustable shocks were for the F-150.
I do like the duel stabilizer from rough country, I just think it might be an overkill for the stock size tires.
Anyway for the rear of the truck
5100 Series - Lifted Light Truck/SUV
post #7 of 14 Old 11-30-2013, 06:48 AM
go with icon suspension... i went with icon shocks and stabilizer and it rides better then most cars...
05 f250 harley edition
studded, deleted
icon shocks with 6in fabtech
sinister coolent filter
sct and ficm tuned
blue spring mod
powermax turbo
175cc
airaid intake
4in turbo back exhaust
black windows
busaandy is offline
post #8 of 14 Old 11-30-2013, 07:06 AM
ZMANN's Avatar
Originally Posted by RuHunting View Post
if u have money to burn that looks decent but they don't lift the rear so I think you may get the cali sag look ?
but honestly I would piece my own and I would use Daystar 2.5" coil spacers and retain the oem coils then I would buy Rancho 9000 shocks and a replacment rear block in the height I determined I wanted the arse end to sit
when I was done
We Miss you Ronnie
ZMANN is offline
post #9 of 14 Old 11-30-2013, 07:25 AM Thread Starter
RuHunting's Avatar
I will say I do not want that Cali sagging arse look. I'm sure I'll get that when I load up the boat, kids and all our gear. I do like the idea of lifting the front of the truck then checking the rear to make level. I want to see what's going to happen when I hook up and weight down.
I do like the icon but still leaning towards the Bilstein.
What are some pro's and con's on spacers and coil springs?
Still haven't spent to much time researching the rear air ride.
post #10 of 14 Old 11-30-2013, 12:20 PM
I absolutely hate the lifts that make the truck sit nose high. It makes the truck look like it's got a bed full of gravel when it's not towing anything. Doesn't instill much confidence when towing.
The_Auto_Tech is offline
