Ball joints help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-26-2013, 04:33 PM Thread Starter
Ball joints help
Hey guys I was told the ball joints on my 99 f250 2wd were shot so I went ahead and tried to replace them. Thanks to all the write ups I found it was pretty straight forward. Just one question I couldn't find an answer to. When I am pressing the lower balljoint into place it puts a dimple in the ring and the balljoint stem can then be moved by hand. Not easily but I don't have to put a lot of muscle into it. So is this normal or should I be getting another one? I wasn't able to move the stem when I pulled it out of the box. Thanks for the help.
Taylor
2002 EXT CAB LB
10" super lift
40" xterrains
Amp Research steps
Dipricol Optix gauges
6637
DP Tuner
4" Straight pipe
tp83 is offline
post #2 of 3 Old 11-27-2013, 04:56 AM
Quoted: 3 Post(s)
You should be able to move them, by hand, but only once they're pressed in or in a vice. It should take quite a bit of pressure, that's why you need something holding it steady before you can move it
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #3 of 3 Old 11-27-2013, 05:32 PM Thread Starter
Thanks we installed the spindle and it seems to be tight.
Taylor
2002 EXT CAB LB
10" super lift
40" xterrains
Amp Research steps
6637
DP Tuner
4" Straight pipe
tp83 is offline
