Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
  #21 (permalink)
Old 08-21-2008, 10:09 AM
Overkill Overkill is offline
We can sell you the system with only the pieces you need (i.e. BDS 4-link, Icon coils, and Bilstein/Icon shocks) and work with you on the shipping.
  #22 (permalink)
Old 08-21-2008, 01:32 PM
gutauckis gutauckis is offline
Overkill, work me out a deal on the BDS 4-link with the icon springs and shocks. You can email me a quote, including the shipping and email to scott (at) gutauckis.com
  #23 (permalink)
Old 08-21-2008, 04:10 PM
Email sent
  #24 (permalink)
Old 10-10-2008, 11:30 AM
rXr rXr is offline
Originally Posted by Overkill View Post
Not to complicate things but we could do the BDS 4-link system with Icon 7" coils and shocks. That would give you the best of both worlds.
Now this sounds like a cool way to go. But, would it be possible
to do it this way:
7" Icon coils and shocks with a 6" BDS standard drop bracket kit,
and a Rise 6" Block and 2" mini spring pack in the rear? Would
that give a level stance? What else would be needed to make it
work ... adjustable track bar? Alignment cams?
Gutauckis, did you ever do this with the BDS 4 link kit?
  #25 (permalink)
Old 10-10-2008, 11:49 AM
DCSpecial DCSpecial is offline
Supporting Vendor
to do it this way:
In order to work with the 6speed?
Yes would could do BDS or CST radius arm brackets with the Icon 7" kit.
  #26 (permalink)
Old 10-10-2008, 12:05 PM
rXr rXr is offline
Thanks for the info on this. Yep, it's for a 6 speed. What I'm
curious about here is if I put all BDS 6" parts up front along with the
Icon 7" coils and shocks, would I need any thing else ... like
the Icon alignment cams or adjustable track bar?
  #27 (permalink)
Old 10-10-2008, 12:10 PM
Supporting Vendor
Personally, I'd do the 7" Icon system minus the radius arm brackets and go with either the BDS, CST or Modded Icon brackets.
Icon system comes with the cams.
While an adjustable trac bar isn't necessary, it is a nice upgrade and assures that the front axle is centered under the truck.
  #28 (permalink)
Old 10-10-2008, 12:18 PM
rXr rXr is offline
Ok. Thanks for all the info that you guys at Truck Toyz provide!
I don't really like the idea of modifying the Icon brackets for
some reason. I think the CST brackets are from a 4.5" kit
for the 08. So, I guess the BDS 6" drop brackets are the
best choice? As soon as I get this all sorted out in my head ( ),
I'm going to give you guys an order call ...
  #29 (permalink)
Old 10-10-2008, 06:01 PM
Supporting Vendor
FWIW, Icon uses the same radius arm bracket with the 4.5" as the 7".
Difference is that the 7" also uses the caster cams vs. the 4.5" that keeps the stock cams.
  #30 (permalink)
Old 10-10-2008, 08:12 PM
rXr rXr is offline
Excellent! Now I've got a plan of attack
