Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 08-19-2008, 05:28 PM
Red_Diesel Red_Diesel is offline
body roll
what are some ways to eliminate body roll on a lifted truck?
Old 08-19-2008, 05:29 PM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
how bad is it?
Old 08-19-2008, 05:30 PM
07stroker 07stroker is offline
I wanna go fast!!!
Maybe a heavy duty sway bar?
Old 08-19-2008, 05:39 PM
its got 38x15.50x20, its not to bad.
Old 08-19-2008, 05:47 PM
their isnt a whole lot you can do with a truck that big...
Old 08-19-2008, 05:57 PM
would different shocks help, or removing the block.
Old 08-19-2008, 06:41 PM
donald lorbeske donald lorbeske is offline
Ifound that if you run arced spring without blocks my truck ride much softer and less bounce but two shock would help too
Old 08-19-2008, 07:26 PM
dayusex dayusex is online now
how would two shocks help?!?!? I could say two shocks if they were mounted outside the rail....... really wish a company made a kit for superdutys to do that
Old 08-21-2008, 08:59 AM
Overkill Overkill is offline
There are a few things you can do to reduce your body roll. Heavier sway bars are an obvious choice. Next, rather than adding additional shocks which will also stiffen your ride, you could opt for custom valved shocks such as Kings or RaceRunners which could be set up to reduce body roll without increasing compression dampening.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
