If you were to lift - Ford Powerstroke Diesel Forum
post #1 of 46 Old 11-24-2013, 04:54 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
If you were to lift
Okay, obviously there are all kinds of lift companies out there. I think on this forum we have established that the higher end kits are better. You get what you pay for sorta thing.....
So heres my question. If you had a budget of 1500ish bucks. Radius , 3 or 4 link, its up to you. What sort of setup would you put together with that. Suspension lift, not leveling kits though. Thats a complete system also, shocks front and rear lift.
What suspension company would you go with?
Big_Smokey is offline
post #2 of 46 Old 11-24-2013, 05:24 PM
Heavy_GD's Avatar
Quoted: 1432 Post(s)
Feedback Score: 3 reviews
1500 installed? are wheels and tires extra?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #3 of 46 Old 11-24-2013, 05:41 PM
Quoted: 3 Post(s)
Can I have $15k to put towards a lift instead?
$1500 is tight....real tight.
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #4 of 46 Old 11-24-2013, 06:16 PM
It depends on what height you want. I decided I wanted a 4" kit on 35's so I bought RC's 4.5" kit and am using 325/65/18. I ended up having about 740 in the lift and about 2000 in the wheels and tires.
The_Auto_Tech is offline
post #5 of 46 Old 11-24-2013, 06:22 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Installed? haha.....its a solid axle! Piece of cake.
Suspension Parts or kit only.....I didn't say wheels and tires......
Obviously 15k budget would be awesome, I'm just curious what the opinions would be if YOU had a budget. At least close to 1500 but for sure less then 2k. When money isn't an issue it's an easy deal.
Got get creative when u have limits. Also didn't specify on height either just that it needed to be suspension and not leveled.
It's not for me, I have a 4.5" icon.......just curious
The Following User Says Thank You to Big_Smokey For This Useful Post:
andrewlemoine (04-26-2016)
post #6 of 46 Old 11-24-2013, 06:27 PM
Quoted: 3 Post(s)
Originally Posted by Big_Smokey View Post
Suspension Parts..... I didn't say wheels and tires......
How much lift? The higher you go the more expensive it gets. What's your trucks details?
01 Ex 7.3l Limited
06 headlights
post #7 of 46 Old 11-24-2013, 08:23 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
depends on the truck its going on....blocked the rear end of my 89 , sleeved the sway bars u front and only bought front super lift springs all for about 600 minus wheels/tires
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 46 Old 11-25-2013, 02:35 AM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Holy cow fellas.....
This is a what would YOU do deal.....so if u drive a 99........... What would you do to achieve lift on the above budget.......2009........ Same deal,. What would you do to your truck on the above budget, etc
Your rig......1500-2000 bucks........suspension lifts only.( not labor)
post #9 of 46 Old 11-25-2013, 02:38 AM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Ha, big red......okay for you I drive a 2009 CCSB f250.
Lift height dont matter! Read the post a little slower. What would U do with 1500-2000 on your truck ........JUST a complete suspension.
post #10 of 46 Old 11-25-2013, 03:55 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Ok here you go: get a lift with radius arms ( no drop brackets ) and a good set of coils. Icon is a good choice. You can buy parts seperate on eBay or a kit online.
Just no Rough Country. I had one and it was ROUGH would have givin it to you for free and save your buddy the trouble.
Obviously a 6" lift will require drop brackets and bigger blocks.
I'm a fan of adjustable shocks too. Set them to how you like it to ride.
$2000.00 will put a quality lift together I did it for less.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
