need help installing front springs on 2013 f250 - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-24-2013, 07:20 AM Thread Starter
fordtrix's Avatar
I'm at a loss at the moment. Have the truck up on jack stands installing carli 2.5" leveling kit.
Removed track bar at frame side
Disconnected sway bar end links
Disconnected brake lines etc.
Removed shocks
Lowered axle as low as possible
Pulled out factory springs
Now I'm having a hard time getting new springs in as they are a couple inches longer and I was barely able to get stock springs out.
Helpppppp please! I must have missed something although ive done all the instructions step by step.
fordtrix is offline
post #2 of 14 Old 11-24-2013, 07:29 AM
7.3pwrstrke's Avatar
Spring compressor, they have rentals at autozone.
If you can't get to autozone, i'd slide the stock springs back in, jack the truck up by the axle and put the jack stands on wood or something to make them taller.
Where are your jack stands? The frame?
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #3 of 14 Old 11-24-2013, 07:32 AM
STROKINFX4's Avatar
I would just go rent a spring compressor, I think it's free at autozone. Not too sure if they fit on springs as big as ours, but it's worth a shot. If it works it will go right in.
STROKINFX4 is offline
post #4 of 14 Old 11-24-2013, 07:59 AM Thread Starter
fordtrix's Avatar
Not opposed to autozone just a 25 mile drive. Have another vehicle tho. Have just read horror stories lol.
The break calipers are about 2" off the ground. My jacks are on the frame. If it was an issue with the truck not being high enough and the calipers hitting I could see it needingto get higher on the jack stands.
Could it possibly be that the radius arms need to be disconnected or something?
ID:	203314   Click image for larger version
fordtrix is offline
post #5 of 14 Old 11-24-2013, 08:08 AM
MSTR-P's Avatar
You're either gonna need a spring compressor or get that bad boy up in the air more.
'03 7.3 - Stock!
MSTR-P is offline
post #6 of 14 Old 11-24-2013, 08:10 AM Thread Starter
fordtrix's Avatar
I dont know how that will help? Nothings hitting the ground
fordtrix is offline
post #7 of 14 Old 11-24-2013, 08:27 AM
Yes, I'd disconnect the radius arms. I know what you're saying. The new springs might be longer, but you still need more play in the axle, right?
I'd only disconnect one side and try it at a time. Once that axle moves, it's usually not fun positioning it back into place.
Side note, harbor freight also has compressors. And I think you'd be fine with a compressor, if you're careful you'll be fine.
post #8 of 14 Old 11-24-2013, 08:28 AM
Bottle jack between the frame and radius arm. Gain a few inches easy.
Rockit is offline
post #9 of 14 Old 11-24-2013, 08:38 AM
Wait, did you not remove the drag link?
post #10 of 14 Old 11-24-2013, 08:54 AM Thread Starter
fordtrix's Avatar
No? Where is that? It did not list that in the instructions. On my way back from autozone now.
fordtrix is offline
