Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 08-16-2008, 07:34 AM
90ranajo 90ranajo is offline
Opinions on Spring re-arch vs shackle flip.
I am wanting to get rid of the factory lift block in the rear. I don't really want to lift it over stock height too much and want to keep as much payload capacity as I can. So I'm looking into either getting the factory 'A' code springs re-arched for a 2" lift to compensate for removing the lift block or doing a shackle flip. The re-arch will cost me about $300 where as the shackle flip will be about $50.
Which method would all of you recommend?
I know with the shackle flip I should lose some payload capacity, I do have air bags to compensate. Also I couldn't find any definitive information on how much lift will be generated with a shackle flip, I've seen anywhere from 2-4" from various sites/sources. If it gives 4" of lift then I would need to lift the front 2" to match, which would bring the price upto about the same as a re-arch.
Old 08-16-2008, 03:01 PM
toddy toddy is offline
I was told that if you rearch our springs they are more likely to break because of the tapered design.
Why are you wanting to get rid of the block?
Old 08-16-2008, 03:15 PM
1. I hate blocks, whether they are factory or aftermarket.
2. I need some more room between the perch and the underside of the bed for my airbags.
Old 08-16-2008, 03:38 PM
DCSpecial DCSpecial is offline
My vote would be the Fabtech 3" rear hanger and shackle that I posted about on the other site.
Old 08-16-2008, 04:25 PM
Dan makes a good point
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
