What size tires 7.5" front 6" rear????? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-20-2013, 07:21 PM Thread Starter
I have a 2000 f250 7.3 4wd that will be getting 7.5 in the front and lifted 6 in the rear. I was originally planning on going with 22x14 xd diesels with 325/50r22 nitto terra grapplers but have since decided to get 22x12 gear 726 with 1" spacers.
Okay so I guess my question is will 35s look small on this setup? or should i try for a 36 or so? I dont want it to rub at all either.
ANY HELP WOULD BE GREAT THANKS
Ranchking is offline
post #2 of 2 Old 11-21-2013, 06:02 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Yea they will look very small. 22" ??? I would stay 20" and smaller on wheel sizes. The smaller the wheel the better it's going to ride. Big difference in ride from 18-20" sidewall absorbs the rough road.
I wish I had 16" instead of 18's can't imagine wanting 22" wheels on a 4X4. ?
All that said 7" of lift you can fit 38" tires and 37's would look fine proportionally.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
